Dell XPS 17 9730
  • myiannakou
    • Dec 2018
    Dell XPS 17 9730
    Can someone please confirm if this laptop should power up and work without the internal laptop battery?
    thanks
  • mon2
    • 14192
    I think it should. Confirm the voltage to ground on each pin of the power adapter connector. Be sure the power adapter is the original. How far on the board does the power adapter voltage travel? Does it reach the charger IC? Most likely will be the BQ charger IC so check the ACN / ACP pin and confirm if the 19v reaches this point. This region is after the usual DCin mosfets.
    • BTubbs200
      Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
      by BTubbs200
      Dell Latitude 5420 P137G
      Board: LA-K491P REV A01
      I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
      Board seems to have no shorts, all power rails are fine and show high resistance.
      When charger is plugged in, voltage is present in 3.3V rail but absent in others....
      01-24-2025, 08:15 PM
    • Johndill
      Dell Inspiron 7567 LA-D993P odd charger issue
      by Johndill
      Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
      There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
      I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
      Here are the tested scenarios:
      1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
      2. With the laptop off, plug in charger (LED says on) & the front charging...
      11-16-2022, 10:55 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • PowerAmpFreak
      Dell Latitude 7280 does not recognize charger
      by PowerAmpFreak
      I have a Dell Latitude 7280 which complains during boot-up that the charger wattage cannot be determined. Tested with two different chargers.
      Any common faults that could be fixed?
      I replaced the DC jack, the original DELL LATITUDE 7280 DC30100Z300 0DP4VC.
      How does the communication between the charger and the PC work?...
      07-28-2025, 07:18 AM
    • exerion5000
      DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
      by exerion5000
      Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
      below normal, as if it were operating in an extreme energy...
      10-15-2023, 02:12 PM
