asus K55VD - no power
  • cephei328
    sparky
    • Feb 2014
    • 49
    • NewZealand
    Hi guys,
    I have Asus K55VD motherboard - Dc to Dc controller chip RT8239b is getting hot - when tested - 3.3 volts Always ON voltage is missing - but 5 volts always ON is present. Don't have schematics to trace the 3.3 volts always ON power rail . Help is much appreciated
    Note: This 3.3 and 5 volts always ON will be present even before pressing power button and feeds EC and charger IC. When power button is pressed 3.3 and 5 volts system power will come out of RT8239b chip.
  • cephei328
    sparky
    • Feb 2014
    • 49
    • NewZealand
    Re: asus K55VD - no power
    Ok guys, I got it. Its EC chip short causing d/c to d/c controller hot. Replaced EC all good.
    cheers
    • dj_ricoh
      • 2073
      cheers
      i swear i try to understand .
      usually EC chips are NUVOTON, ENE, ITE.
      What EC chip did you have?
      or you call Mosfets EC?
      • atsio
        • Oct 2013
        • 819
        • Greece
        EC ic gets 3.3v (power) from 5v and 3.3v regulator. EC ic was shorted, so 3.3v rail was sorted.
        • cephei328
          sparky
          • Feb 2014
          • 49
          • NewZealand
          Atsio was right, EC ITE8517E gets 3.3 volts standby voltage from RT8239B system power controller. When EC is short no 3.3 volts and chip gets hot. Cheers
          • gelf1969
            • Aug 2014
            • 4
            Hi people,
            I'm having trouble locating the RT8239B, is it under the CPU cooling pipes?
            Any help would be appreciated.
            Cheers
            gelf1969
            • gelf1969
              • Aug 2014
              • 4
              I see my bad, must learn to have "coffee before tronics".
              You were referring to a short with the EC ITE8517E causing a loss of continuous power to the RT8239b causing the issues.
              Sheesh, might have my work cut out for me as a novice solderer sorting that ITE8517E replacement.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3599
                • slovakia
                just good flux and hotair station for removing, good flux and flat tip to soldering
                • gelf1969
                  • Aug 2014
                  • 4
                  Would a Hot air gun work? Also would solder paste be a better solution for surface mounting?
                  Seriously don't mind if it goes belly-up since It has been thrown out.
                  • Ramee
                    • Jul 2014
                    • 218
                    • Israel
                    Why don't you invest at least 1K usd to start. If you would like to become a goood technician, always do the proper way
                    • alter_sack
                      • Aug 2015
                      my board shows the same symptoms.
                      I do not know a lot about microelectronics, but I believe an EC would have to run some device-specific routines. Does this mean I have to get a programmed chip from another k55vd board, or does any IT8517E off ebay just work out of the box?
                      PS in case anyone is still looking: RT8239B is hidden under the heatpipe, a 3x3mm chip marked "jc ed h21".
                      • satanicko
                        • Aug 2016
                        • anit
                        hi i have a same board Asus K55vd board but no display I need your help guys tnx
                        • engsaif
                          • Apr 2017
                          • iraq
                          hi friends pleas i need schematic diagram asus k55vd ...
                          • Legion007
                            • Oct 2017
                            • 6
                            • Narniy
                            Help me find a malfunction!
                            in the attached PDF note my measurements.
                            any help...
                            I place the necessary files for help
                            • Legion007
                              • Oct 2017
                              • 6
                              • Narniy
                              the LED energy is constantly on. LED lock 1 flashes twice. LED lock A glows constantly. After two seconds all the LEDs go out. the system does not start. the screen does not light up.. when the memory is removed. LED energy is shining. LED lock 1 is shining, constant glow. the processor is warming up, also warm bridges. After some time the fan turns on. the monitor does not light up. this may indicate a functional bios?
                              • Legion007
                                • Oct 2017
                                • 6
                                • Narniy
                                PM_RSMRST & PM_PWROK low levels 3,28V (should be 4V)
                                ALL_SYSTEM_PWRGD 3,33v but the laptop turns off, if dismantled memory laptop will not turn off, but the screen does not glow
                                any ideas ???
                                • piernov
                                  • Jan 2016
                                  • 4435
                                  • France
                                  Those voltages are 3.3V AFAIK. If RSMRST# is low, the system shouldn't react to power button at all.
                                  • Legion007
                                    • Oct 2017
                                    • 6
                                    • Narniy
                                    problem with bios? I have no experience in diagnosis. any assumptions on the steps?
                                    • Legion007
                                      • Oct 2017
                                      • 6
                                      • Narniy
                                      the failure of the BIOS program was confirmed, at the comparative analysis of a dump of a bios from the given mb and the bios of the downloaded from a network with obviously working mb the distinctions. after the firmware the notebook revived. updated the firmware without soldering the chip with a clothes clip.
