Only the power LED: ThinkBook 15-IIL
  • fk-shokai
    • Dec 2024
    • Japan
    Hello! Please help me.
    ThinkBook 15-IIL(M/B DALVACMB8D0 Rev) won't start.
    When I connect the power adapter, the battery LED, power LED, and access lamp will light up, but after a while the access lamp will start flashing.
    The monitor backlight does not light up and the CPU fan does not spin. CPU and RAM sockets are getting very hot.
    Any ideas?
    : Already implemented
    ・Full cherge and Full discharge battery.
    ・Replace SSD & RAM
    ・Replace CMOS battery
    Thank you.
  • mon2
    • 14003
    This is of concern. Remove all power. Meter in resistance mode. Measure the resistance to ground of the VCORE inductors that power the CPU. What may have happened is that the high side mosfet(s) may have leaked and under this event, the high adapter voltage will pass through onto the very low voltage rails used by the CPU. Then this will become a no repair. Unfortunately, this happens often on laptops.
    The multiple inductors used by the multiple power rails that operate in phases to keep the logic board power supplies cool should be located nearby the CPU. Each such inductor / rail takes turns to turn ON then OFF when another takes it's turn to do the same. This way, no single power rail is burdened by the heavy current demands of the pig CPUs.
    • fk-shokai
      • Dec 2024
      • Japan
      Dear mon2
      Thank you for your reply.
      I am currently studying surface mount components, and I understand that a high side MOSFET is a component like the one in the image. I tried measuring the resistance values ​​of the three terminals of a MOSFET at multiple locations. However resistance values ​​varied greatly, and sometimes no value was obtained...
      Looks like I'll have to actually look at the circuit diagram.
      This time I purchased the machine as a teaching material, so even if the worst case scenario requires a CPU replacement, I may still carry it out
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
        03-31-2024, 02:12 PM
      • khelane
        test active pfc power with lamp test
        by khelane
        Hello
        I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
        Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
        Is there a way...
        06-03-2025, 01:00 AM
