Dell XPS 9343 LA-B441P
  • sauce
    • Sep 2013
    • 149
    • France
    I would like some help on my wife's laptop Dell XPS 9343 with LA-B441P motherboard.
    AC adapter is not recognized so I bought another used one and still the same !
    It was of course working with the old one the bios was saying 45W adapter but now it says adapter unknown.
    I don't know if the used one is also defective or it's a motherboard issue.
    I have already repaired this laptop to give it to my wife (the PD102 TVS was bad).
    For now what I checked :
    - If i measure old adapter the center pin measure nothing in diode mode so I think the wire it's cut somewhere (so it's normal the laptop does not recognize it). 19v is ok because the laptop can start but not charging battery and the laptop is very slow
    - I measure the used adapter I just receive and the center pin measure 0.280 in diode mode
    So here the voltages on the motherboard when adapter is plugged (the new used one)
    The voltage on PQ100 on pin 1 and 3 is quite low 0.6v ! I think we must have 3.3v here ? Pin 2 is 5v
    So I desoldered PL102 to isolate each part and now I have 3.3v on PQ100 (pin 1 and 3)
    So the only part on the other side of PL102 is the center pin so what does it means ?
    If I put 3.3v on center pin of the ac adapter with my power supply the current is 8mA.
    I replace PD102, PQ100 and PQ101 but still the same.
    Thanks in advance and sorry for my bad english I am french.
  • mon2
    • Dec 2019
    • 14713
    To me, the fault appears to be a mechanical issue with the dcin power jack.
    Leave PL102 off the board. Attach the power adapter but do not plug into the ac wall socket.
    Test the center pin in diode mode using the PL102 pcb pad. What is the measurement?
    • piernov
      • Jan 2016
      • 4439
      • France
      If the AC adapter draws 8mA the voltage will collapse, no point in troubleshooting a board without a known good genuine Dell AC adapter.
      However a resistor needs to be connected between the supply voltage and the 1-wire ROM, otherwise the 1-wire ROM will try to short full current to ground to send data.
      That said it's also common for PR103 to be damaged.
      • sauce
        • Sep 2013
        • 149
        • France
        So I remove PL102 and in diode mode red on ground and black on PL102 pad (side of the center pin) I measure 0.165 same if I measure directly on the adapter center pin so good connection from PL102 pad to center pin.
        • sauce
          • Sep 2013
          • 149
          • France
          I will try to replace PR103 even if the value is 33 ohm on the board.
          I think the used ac adapter I bought is faulty too
          • sauce
            • Sep 2013
            • 149
            • France
            I forgot I have a AC adapter from a Dell Optiplex, test it and it works !
            Never trust a seller !
            Thank you for your help.
            • chinsuckseed
              Need Help to Boot with External Display XPS 13 9343
              by chinsuckseed
              I need some help !! I just update Display firmware of XPS 9343 but it 's wrong firmware the system prevent me from BOOT and got 8 beeps even i press FN+F8 to connect HDMI to external Display then FN+F12 to select Boot Menu, it stucked at Dell Logo and preparing to Boot Menu, i would need your help to boot to an external display I have dump my BIOS of my XPS 9343 . pls advice me would be highly appreciated. THank u very much
              https://drive.google.com/file/d/1pXd...usp=share_link
              02-23-2023, 06:48 AM
            • sauce
              Dell XPS 13 9343 boardview
              by sauce
              I am trying to repair a Dell XPS 9343 motherboard and I think I found a faulty Mosfet (PQ201).
              But I have another problem 2 components are missing (PL104 near DC jack connector and another capacitor near PR202).
              I have only the schematic so I can't figure out what is the value of the capacitor because there is no marking on PCB for this capacitor.
              So I would like to know if someone has the boardview of this card (LA-B441P).
              It's only for my personal use I would like to keep this laptop for me.
              Thank you.
              10-09-2022, 06:41 AM
            • aminsab
              Identify and read XPS 9343 Bios chipset
              by aminsab
              Hello, how i can find and read Bios chipset of XPS 9344.
              There is 2 of W25Q64FV, when i try to read theme on Programmer it cant detect them.
              (ch341a programmer)
              -is there a spicific way to do that ?
              Thank you....​
              02-01-2024, 04:18 AM
            • Metropolis
              Dell XPS 13 9343 (No Power)
              by Metropolis
              Hi everyone, I have a Dell I thought it might be the bios being damaged but I would like to ask if this has happened to any of you before. Thank you
              10-30-2023, 02:49 AM
            • warguello
              XPS 13 9343 Identify burn motherboard component
              by warguello
              Hi, please I need your help with a serius problem, months ago my Dell XPS stopped charging, I tried all the recommended methods (try original charger, power connector cable, drain battery) but nothing worked. finaly I disassembled the motherboard and discovered that near the "PQ101" there is a burned component, but I cannot identify it to replace it. I leave a couple of photos, maybe you can help me. thaks a lot.
              I am not an expert in electronics, and less in integrated circuits. When I tried to clean the surface of the component, it disintegrated a bit....
              10-31-2022, 10:36 PM
