HP gaming 15-0013dx quanta G3HA no video, screen polarize on and off loop
  • ferah831208
    • Aug 2019
    • 60
    • Cuba
    I have an HP gaming 15-0013dx laptop , motherboard quanta G3HA with AMD Ryzen 5 cpu and Nvidia discrete grsphics card. The laptop turns on and u can see the screen polarizing on and off in a loop but no video signal. All voltages are ok measured and stable (I checked all with oscilloscope). This schematics don't have power sequence but I'm using a similar sequence from another laptop with AMD CPU and I get all to the point CPU must release apu_pwrok and apu_rst#, this signal comes valid only for the period of time the screen is polarized and they disappear and same loop behaviour (active/inactive). The rest of mb voltages don't toggle, CPU voltage changes value but this is logical because apu_pwrok goes to pwrok pin of VRM chip and analyzing datasheet when this signal disappear the SVI interface is disabled and VR returns to Vboot voltage , so it's working like it should. I flashed 4 bios versions and KBC. Everytime I flash bios first time I power on, I get video signal and this message "system bios pending image is being cleared", it goes to the end, turns off power on again and same loop behavior and signals toggling. I tried different memory modules in both positions, if I remove memory stick CPU voltage is stable and all signals associated and I get blinking pattern in keyboard. But everytime is going to continue posting after ram is detected i get this. Any ideas?? Faulty CPU maybe?? 🤷🏻‍♂️. Maybe I'm not thinking about something. Thanks in advance if someone can help
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    I faced the very same problem on this platform and asked for any suggestion in this forum. But unfortunately, could'nt understand the reason behind it.
    This G3HA mb is still lying with me with exact same symptoms. The boardview avalibale is not the exact one for this platform adding to misery.
    This problem i've faced on 3 occassions and everytime its a HP with AMD APU. So i too doubt it has got something to do with ryzen apu but that doesnt explains why this malaise is not present in other brands.
    I flashed all version from HP website,flashed EC,replaced EC,replace main eeprom chip,replaced ram sticks but failed miserably all the 3 times.
    I'm still in the dark about this problem.
    • ferah831208
      • Aug 2019
      • 60
      • Cuba
      Well if u encounter any solution in the future please post it here. I've struggled with this for too many hours and I have my workshop really full of other laptops and cannot dedicate more time to this one, but I'm really curious about this fault. Exactly what u said, boardview is not identical but I've managed to find test points for many signals and the symptom is exactlywhat I posted before. Apu_rst recycling after detecting RAM. In Intel brands I use a post card tl611pro for lpc debug but with AMD, debug post codes are not so clear 😔. Anyway I want to ask u, maybe u have info about this, in a working laptop after u flash bios in this models or similar, the warning message about clear bios pending image is normal?? I mean it is supposedly to this step and then reboot and works normally after it finishes configurating bios??. Because i think when u flash bios it detects the first time it must update some module and the. Reboot and initialize and in this step evidently this motherboard gets stucked. I want to add this laptop came with a thermal pad in the middle of CPU I think it was a factory manufacturing mistake, so CPU got really warm and laptop shutdown. I removed it, change thermal compound and worked for a month and returned back with this symptom. That's why I believe it could be a CPU fault.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        clear bios pending image is normal?? -No too me its not normal. We'll flash bios on so many laptops but never get this message.
        I beleive this message is 'coz some residual files remain somehere and it fails to clear that. But the million dollar question is where?
        Honestly, i still dont know.
        Sure, I'll update this forum if ever i get a solution.
        • ferah831208
          • Aug 2019
          • 60
          • Cuba
          That was my concern, I've never seen that message, but again it's AMD, a modern model, so I was not sure, all info I find about clear pending image is regarding bios corruption, and evidently is not the case, but I thought maybe it's a common behaviour in this more up to date models, before it had to flash or write something in EC chip for example, but for me it's also weird 🤔😔.
          • Takeatry
            Yet another Samsung QLED Boot Loop
            by Takeatry
            Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
            10-04-2024, 02:57 PM
          • rs2pac
            For HP 15-ec00 DA0G3HMB8D0 REV:D Quanta G3HA
            by rs2pac
            Need help finding schematic / boardview
            Notebook: HP Pavilion Gaming 15-ec0063
            Motherboard info: DA0G3HMB8D0 rev
            Platform: QUANTA G3HA
            Motherboard Part Number: L71929-601
            Notebook Part Number: 9MT23PA
            The device works fine, but the USB 2.0 and HDMI output does not work. The power button&USB board is damaged. The USB charging port power switch controller is completely dead.
            Thanks.
            04-01-2022, 10:49 AM
          • lpraderi
            Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
            by lpraderi
            Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
            In some cases to use LVDS screen PCB use converter IC RTD2132/6
            Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
            at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
            Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
            11-25-2023, 09:31 AM
          • blaster_
            Samsung UE49MU6105K - boot loop, horizontal lines
            by blaster_
            Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
            Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
            06-22-2022, 05:19 PM
          • Stefano Crivellari
            Lenovo Legion 5 (15ITH6H) kind of boot loop but not sure
            by Stefano Crivellari
            Hi, I wonder if anyone can help me fix my Lenovo Legion 5 (15ITH6H) laptop. Basically, after a windows update the computer would not boot anymore. When powering on the laptop the screen has no backlight and nothing would show up, using an external monitor did not help. However, the laptop would still spin up the fans and turn on the keyboard backlight. The keyboard backlight intensity function key would work and the power button led and the charging led are also working. I've tried every possible combination of key press and power button hold down time but did not change anything. At this point...
            01-14-2025, 03:49 PM
