Asus X540U No Power On
  • shamaltech
    • May 2023
    • 109
    • Sri Lanka
    I have an Asus X540ubr laptop of my customer.
    The problem is it's not powering on.
    When I check,all the voltages are ok.
    I tried heating the motherboard with my soldering iron,after that it started to work fine and also charges the battery.
    After leaving it turn off for 1 or 2 hours,then it's not turning on back again.
    When I heat up the motherboard again,it turns back on again.
    What would be the problem of this?​
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Start checking powergood signal. One of the diodes in powergood lines may be bad.
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • ShadowAi
      ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
      by ShadowAi
      Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
      Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
      After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
      03-15-2024, 10:46 AM
    • meraklinetx
      Asus Z97-a power cycle, no boot no cpu voltage
      by meraklinetx
      Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
      05-10-2023, 06:08 AM
