820-02098 stuck at 5volts and cycling at 0,000 amp - 0,030 amp
  • meineiid
    • Jan 2019
    • 9
    Hi i got an A2442 with liquid damage. The Board is stuck at 5volts and cycling at 0,000 amp - 0,030 amp. Its not in dfu or recovery, i also tried to set it in dfu but doesnt work. With the old Macbooks I could always go through the power sequence, but with the new ones I don't know. I measured these rails PPBUS_AON= 12,35v PP3V8_AON= 3,8v PP1V8_AON= 1,8v PP5V_S2_MAIN= 0v . In logi wiki i says that "most important power rails now are pbus, 3v8 and 5v_S2" but i dont think its the PP5V_S2_MAIN i think something before that.
    Can someone help?
  • mon2
    • 14631
    Being USB Type C powered, start with a good review of the CD321x ACE power delivery controller. Each and every such controller must be functional to allow for the 20V power delivery contract to be selected to power this logic board.
    Review the LDO rails of the CD321x ACE controllers. You can use the following as an excellent guide:
    https://logi.wiki/index.php/CD3215_Bootup_Sequence
    Be sure to watch this video (if not done already):
    https://www.youtube.com/watch?v=CAGnMR1aVuE
    Louis Rossmann has another on the same topic.
    • high-tech
      Samsung UN55F7050AFXZA ver. TD01 power cycling
      by high-tech
      Hello everybody, I could use some help on this one... It's got me guessing...
      I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
      (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
      (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
      (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
      (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
      9. ground (PWM2) 10. 0.9 volts cycling...
      09-15-2020, 03:39 PM
    • usbdevice
      Acer X223HQ (Version Bbd) on/off-power-cycling
      by usbdevice
      Hi all
      There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
      https://www.badcaps.net/forum/showthread.php?t=50657
      https://www.badcaps.net/forum/showthread.php?t=40512
      The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
      It's my dad's old monitor. He...
      08-05-2022, 02:21 AM
    • iMuhtaseb
      A2279 - 820-02841 cycling
      by iMuhtaseb
      A2279 (14" M2 Pro | 820-02841)
      No power - switches to 20V for a swift moment then starts cycling/switching on all USB-C ports.
      Board is clean.. I looked over it three times and found little corroded caps for a display data lines.. replaced them and they have nothing to do with the issue.
      Customer is using a branded USB-C to MagSafe cable. I looked for shorts (diode mode) nearly all lines, PPBUS, 3v8_AON, 5V_S2, 1v2_S2, 1v2_AWAKE, 1v8_AON.. and coils around master PMIC and slave PMIC; all reads normal.
      I suspected that ISL might be bad, took an educated...
      09-23-2025, 06:58 AM
    • dbuergi
      MacBook A2141 one USB port dead and one power cycling
      by dbuergi
      I got a 16inch MacBook Pro showing 5v and 0,3a on the left ports and right side has one power cycling and one showing nothing. The one cycling shows 30c under thermal camera. Surrounding components show no corrosion or any shorts.
      Any ideas what to check next? The whole board looks clean compared to the other A2141s i saw....
      04-25-2025, 11:40 AM
    • mon2
      A2141 820-01700 Power cycling (DFU worked ok)
      by mon2
      Hi. Working on an A2141 that is power cycling. Powers up fine (20V @ 3.1A peak) -> fan spins ok and then at a higher speed (after we removed the trackpad so the sensors are missing) -> chimes ok but after the high fan spin -> power cycles and repeats this loop. We did manage to DFU the unit with revive mode (4/4 steps completed ok) -> resulted in a brief padlock graphic before power cycling. Unable to toggle the keycaps led since the boot does not reach this far of the cycle.
      Q: Does the DFU process validate that the nand flash is OK ? We do not wish to restore this board...
      11-24-2023, 12:17 PM
