dell g3 mlk n18p 19795-1 no display
  • ahmarzo
    • Mar 2015
    • 173
    • india
    have dell g3 laptop motherboard with part no g3 mlk n18p 19795-1 with no power and 19v shorted the problem was nb694 part no pu5401 was shorted upon replacement shorting was removed and aftergiving power charging ic intersil 95522h got burned. but everything was working perfectly on battery so i changed the charging ic and now the laptop is contiously power on and off on both battery and charger with no cpu core voltage
    here is the link for schematics https://www.badcaps.net/filedata/fetch?id=2099938 .
  • ahmarzo
    • Mar 2015
    • 173
    • india
    Have tried another charging from working laptop but the laptop power on and off in a loop.please help
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      Check the soldering of the new charger ic. Maybe put flux around it and reflow. Was the IC new, or reused from another motherboard ?
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
        Dell Thunderbolt Firmware
        by SMDFlea
        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
        The SKU is in brackets (****)
        EDIT: NVM65...
        01-26-2025, 06:22 AM
      • F R 2568
        Dell Latitude 5420 does not start (no post) need help to find the reason why
        by F R 2568
        Hello all,
        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
        If the laptop is only connected to the AC adapter (battery removed):
        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
        The power/battery...
        01-08-2025, 05:45 AM
