dell g3 mlk n18p 19795-1 no display
  • ahmarzo
    • Mar 2015
    • 171
    • india
    have dell g3 laptop motherboard with part no g3 mlk n18p 19795-1 with no power and 19v shorted the problem was nb694 part no pu5401 was shorted upon replacement shorting was removed and aftergiving power charging ic intersil 95522h got burned. but everything was working perfectly on battery so i changed the charging ic and now the laptop is contiously power on and off on both battery and charger with no cpu core voltage
    here is the link for schematics https://www.badcaps.net/filedata/fetch?id=2099938 .
  • ahmarzo
    • Mar 2015
    • 171
    • india
    Have tried another charging from working laptop but the laptop power on and off in a loop.please help
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      Check the soldering of the new charger ic. Maybe put flux around it and reflow. Was the IC new, or reused from another motherboard ?
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • F R 2568
        Dell Latitude 5420 does not start (no post) need help to find the reason why
        by F R 2568
        Hello all,
        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
        If the laptop is only connected to the AC adapter (battery removed):
        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
        The power/battery...
        01-08-2025, 05:45 AM
      • diamon
        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
        by diamon
        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
        Pictures of these boards:
        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
        Dell...
        02-28-2024, 12:51 PM
      • lalle-
        Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
        by lalle-
        Hello!
        I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
        [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
        I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
        The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
        I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
        08-11-2024, 02:01 PM
