Macbook pro a1989 - 20v not turning on
  • obelix24
    • Jun 2023
    • 291
    • Slovakia
    I just got Macbook Pro a1989 that when connected to charger is getting 20V and up to 1,3A (when battery is connected) 0,8A when battery is not connected.
    but after few seconds it jumps to 0A and restarts (No chime, no picture)
    every port is taking 20V so all CDxxxx should be ok.
    there was corrosion on LCD connected (enough to clean no pin is burned) - so i cleaned it and it looks ok.
    I've checked under termal camera and there are 2 hotposts on U7800 (but this chip looks spotless) i've checked all
    L7821,22,20,19
    L7817,16,14,15
    L7809,08,07,06
    all diode values (according to FlexBV looks ok)
    hotspots are in the corner where pin 1 is located and then on opposite side around pins 90-180
    is this normal behaviour ? or it is possible that U7800 is faulty ?
  • mon2
    • 14086
    Sounds faulty. At least remove and check under the device to see if there are any issues.
    • obelix24
      • Jun 2023
      • 291
      • Slovakia
      ok I've replaced this U7800 and not MacBook stays on it draws healthy 20V and charge battery.
      but there is still no chime or display.
      I've connected it to another MacBook and revived, restored via Apple Configurator 2 (successfully finished)
      but still no chime or anything on the screen.
      I'm able to put MacBook to DFU mode and execute restore but nothing on screen, Touch Bar, CAPSLOCK light is also not working
      but trackpad is clicking so this means T2 is ok ... also Revive was finished so BridgeOS should be also ok.
      I'm using know good screen + keyboard.
      I've tried to connect this MacBook via HDMI to TV to see if there is any output and nothing (I've tried with internal screen connected and also disconnected (no difference still no output)
      Any idea what to do next ?
      • mon2
        • 14086
        What is the current draw? Do you see power cycling on the USB C meter?
        • obelix24
          • Jun 2023
          • 291
          • Slovakia
          With battery connected it climbs to arround 20v 2,5A a stays around
          with battery disconnected it goes to 20v 0,6A
          it's stable no cycling
          • mon2
            • 14086
            What is the voltage to ground of PPBUS_G3H?
            • obelix24
              • Jun 2023
              • 291
              • Slovakia
              With battery disconnected i got stable 12,65V on PPBUS_G3H - on USB-C meter i get 20V 0,6A
              When battery is connected it slowly rises from arround 11,4V to 12,46V (here it stays) - on USB-C meter i get 20V 2,63A
              • mon2
                • 14086
                Test the smbus voltage on the battery pack with the adapter connected.
                Review the current sense resistor path at the input to the isl controller that creates ppbus_g3h.
                • obelix24
                  • Jun 2023
                  • 291
                  • Slovakia
                  both SMBUS_3V3_BAT_SDA and SCL i'm getting 3,3V
                  i've removed CPU heatsink and checked with thermal camera (compared to working icloud locked board) and i have one hotspot approx in the middle of the CPU
                  I've checked EDP_INT_AUX_P and it looks ok - Diode mode 0,2
                  • p0cas
                    • Feb 2025
                    • Portugal
                    I have the same problem you find a solution ?
                    • obelix24
                      • Jun 2023
                      • 291
                      • Slovakia
                      No i haven’t i’ve used T2 from that board to another icloud locked to make it usable again.
                      • modtool
                        Macbook Pro A1989 fallen, reboots if touchbar connected
                        by modtool
                        Hi to all,
                        the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
                        Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts...
                        11-10-2023, 07:42 AM
                      • gugutm
                        a1989 820-00850 stuck at 5v 0.041a Help
                        by gugutm
                        I'm new to the forum,sorry english is not my first language too, i got a basic plus knowledge, but now i am in this situation where i need some help , i spend good few days reading forums , here and outside , to help my problem solve, with no luck
                        long story short, i bought macbook pro a1989 820-00850, clean no water damage which was stuck on 5v 0.200/300a i read a lot of forums what that could be , it indicated to faulty corrupted t2 rom
                        of course before jumping to conclusion and connected to DFU , i believe i done basic checks...
                        01-04-2025, 09:35 AM
                      • ErinV
                        MacBook Pro A1989 820-00850-A not powering on
                        by ErinV
                        Hey everyone!
                        I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
                        I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
                        The diode voltages around all 4 CD3215's seem fine.
                        For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
                        09-30-2024, 10:21 PM
                      • Madoy104
                        Macbook Pro A1989 - No image, working fine with external monitor
                        by Madoy104
                        I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
                        08-15-2024, 10:01 AM
                      • CornholioGSM
                        Macbook Pro 15" 2018(820-01041-A) Freezing, Rebooting, Kernel Panics but only with connected Battery
                        by CornholioGSM
                        I have here one interesting problem.
                        Laptop comes to me with freezing and rebooting problem. All inside was relatively clean and no water damage. Only visible problem was one swolled cell on battery...all was looking like batt problem.
                        I have put inside new - not original batt, but problem with freezing still. I am able to boot into os, then pc can run few seconds, then freezes and reboot and reboot until force power off.
                        Quickly i am able to see battery information...batt is detected normally in os with power cycles hours...
                        06-25-2024, 12:27 PM
