MacBook A1989 - no power 5V 0.05A
  • tommy97
    • Mar 2023
    • 152
    • United Kingdom
    Hi guys i've got A1989 with no power, draw 0.05A with 5v, checked PPBUS_G3H 12.28V, PP3V3_G3H 3.3V, there is no corrosion neither liquid damage. Exactly same reading on each port/each side. I don't have schematics near my however on the 2.7v SSD coils I had reading of 140Ohm's is that normal or failed SSD?
    No short find, with and without battery, same reading.
  • mon2
    • Dec 2019
    • 14207
    Ppbus_g3h is too low. Check the voltage to ground of the smbus lines on the battery connector (SDA & SCL).
    • tommy97
      • Mar 2023
      • 152
      • United Kingdom
      Both SMBUS Lines are 3.3v
      PPDCIN_G3H_CHGR 5V to the ISL
      • mon2
        • Dec 2019
        • 14207
        SMBUS lines are not shorted. Ok. But PD controllers are not negotiating the boost voltage of 20v from the PD power adapter. The ISL (U7000) is operating in boost mode, not buck mode (20v to PPBUS_G3H voltage).
        Focus on the CD321x controllers and the article by piernov and others on how 20v is selected. Review the LDO rail on each ACE controller to be sure one is not defective.
        https://logi.wiki/index.php/CD3215_Bootup_Sequence
        • tommy97
          • Mar 2023
          • 152
          • United Kingdom
          Readings on each port
          PP3V3_UPC_XB_LDO 3.3V
          PP1V8_UPC_XB_LDOA 1.8v
          PP1V8_UPC_XB_LDOD 1.8V
          PP1V1_UPC_XB_LDO_BMC 1.1V
          HV_GATE1/2 (couldn't find on this board)
          PPDCIN_G3H 5v
          PPCHGR_VDDA 5V
          PM_EN_P3V3_G3H (couldn't find on this board)
          PP3V3_G3H - 3.3v
          PP1V2_G3H_SMC_VDDC (couldn't find on this board)
          USBC_XB_CC1 1.75v​
          • mon2
            • Dec 2019
            • 14207
            Remove all power. Meter in resistance mode. Measure the resistance to ground of each inductor. Check if each power rail is without a short.
            Test with a dfu process.
            • tommy97
              • Mar 2023
              • 152
              • United Kingdom
              Laptop was in DFU, after revive laptop works however is extremely slow, battery fully charge, touchbar keyboard trackpad are working.
              • Palafox
                • Nov 2023
                • 9
                Did you ever find out what was causing the mac to be so slow? I'm have a similar issue
                • mon2
                  • Dec 2019
                  • 14207
                  If a mac is running slow, confirm the OS is not to blame. The logic board may be unable to ping one or more of the sensors and then the CPU speed will be throttled for safety. There are such sensors inside of the trackpad and is a common fault. Any spills on the keyboard / trackpad? Review the cabling in this area. Replacement trackpads and cables should be available on Amazon or Mobile Sentrix. For extreme cases, the bios may need to be reflashed if corrupt but your unit is booting so review the other issues. You can run a diagnostic to check on the error code leading to this hauldown of the CPU speed.
                  What is the history? If the power adapter is under rated, the CPU will also be throttled and the battery charging will halt. Confirm the external power adapter.​
                  • tommy97
                    • Mar 2023
                    • 152
                    • United Kingdom
                    All components were good as on the new motherboard it works fine, i finally replaced motherboard as i needed data of the device however to transfer 100GB it took 2days.
                    • ErinV
                      MacBook Pro A1989 820-00850-A not powering on
                      by ErinV
                      Hey everyone!
                      I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
                      I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
                      The diode voltages around all 4 CD3215's seem fine.
                      For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
                      09-30-2024, 10:21 PM
                    • Madoy104
                      Macbook Pro A1989 - No image, working fine with external monitor
                      by Madoy104
                      I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
                      08-15-2024, 10:01 AM
                    • PITERPENY
                      Macbook A1989, 820-00850, won't boot. 20V, 0A.
                      by PITERPENY
                      Today I have a MacBook A1989 at work 820-00850. When assembled, the laptop switches to 20 volts but the consumption is 0.00 ampere. if the motherboard is on the table then the consumption of all ports is 5 volts and0.35 amperes and does not go to 20 volts only if you assemble a MacBook.
                      Here are some measurements, maybe someone can tell what the problem is.
                      The initial problem was a burnt out induction coil L8504 (replaced).
                      When connected to another MacBook, it constantly hangs in dfu and cannot install updates, something is wrong.
                      here are some measurementsmotherboard...
                      01-16-2024, 02:19 PM
                    • Nikan.e
                      MacBook A1989 repair / no CPU voltage no boot signs
                      by Nikan.e
                      Hello everyone.
                      I have recently obtained a MacBook Pro A1989 model with a touch bar and Apple ID. Unfortunately, it does not want to start up.
                      No CPU Voltage.
                      U7800 Does produce voltages.
                      T2 Chip warming up very very little.
                      I do have voltages like 1.8, 0.9, 3.3, 2.5 volts, etc., present. I did not find any short circuits. Unfortunately, the device has no touch ID/start button. So, I have used the debug jumper to put the device into DFU mode. - It is getting recognized as a Macintosh while not in DFU mode and as Apple (DFU) while in DFU mode....
                      11-24-2023, 11:55 PM
                    • biosdi
                      MacBook Pro A1989 trackpad and keyboard not working
                      by biosdi
                      Hi guys.
                      I Just replaced battery on my MacBook Pro A1989. Unfortunately doing that, I’ve broken the trackpad flex cable (821-01701-a), and I’ve already ordered a spare one. At the same moment I’ve noticed that also the keyboard it’s not working anymore and I’ve found an SMD chip unsoldered and moving freely inside the backplate. I can read L20L on the chip. Is something could explain the keyboard not working or the keyboard doesn’t work due the unconnected trackpad?
                      thanks...
                      04-17-2025, 09:42 AM
