Hi ive got 2 cq61 laptops but only one screen which im having trouble with both of the mother boards one when plugged in just has a white screen and the other when the screens plugged in works but has no backlight am i right in thinking that i need a new inverter?
compaq cq61 not working
Re: compaq cq61 not working
Forgot to mention they both work fine on external screen -
did you switch them ? white one without backlight?Just cook it! It's already broken.Comment
I Think you have AMD or nvidia version of CQ61 try to reball the north bridge or GPU chip
in most cases reball solve the problemComment
If the screens plus the inverter are ok, then reball the gpu,
i don't think the north brige, cuz it work on extern.The Night Drop Down, I Will Keep Try Until..., You Never know.
Dushi Kòrsou, Nos Tei.Comment
Hi my friend reballed both of the motherboards and still have no backlight through motherboards I used in car dvd screen inverter and the screen lights up so its not the backlight bulb so im quite stuck is there a circuit on the motherboard that powers the inverter? I get 18v on inverter plugComment
There's schematic...
What's the behaviour of both boards after reball???
Still the same?Attached FilesComment
Right I tried to measure voltages on cn1 and managed to blow up the mother board lol so have to try and fix the other one (one with picture no backlight) on the inverter the voltages are as follows
1-18.64v
2-0.0v
3-3.26v
4-0.0v
Im sure pin 4 is ground and pin 1 is the right voltage but what should 2 and 3 be?Comment
Hi! Does anyone have the boardview for the following MB:
Compaq CQ61-407EF
Compaq CQ61-405SF
Thanks in advance-
Channel: Schematic Requests ONLY!
by dicky96Hi guys, I have an old laptop here I'm just trying to fix for the fun of it really
The top part, maybe 25% or 33% of the screen display works, (DOS boot text or bios screen, I have no HDD fitted) but the bottom part is all white.
On an external monitor connected to the VGA the picture is good.
So basically I have a horizontal division, below which the screen is all white. There is no apparent damage to the screen or any vertical lines
I tried cleaning the pins on the LVDS connector plug/socket as thy looked a bit dirty (18 pins plus... -
by Wachenaggoi got this iPhone 6s Plus Ghosting/Doubling Image intermittent LCD Screen not working and Touch Not working
i check CHESTNUT Voltages its there or does anybody know what is this issue....05-08-2023, 08:11 AM -
by purepowerGood day to all any one here ,,I need Lenovo laptop IdeaPad c340 touch screen driver , I installed driver ,,but it's doesn't work,I go to Lenovo support ,I installed right driver from there and still no luck ,, touch screen not working ,,01-04-2023, 12:44 AM
by String2016I need a working bios on this acer predator
MODEL:ACER PREDATOR PH315-52 54KC
S/N:NHQ54SP00A024028992600
SNID:02401039326
Attached is the original bios no display problem black screen keyboard lights on...-
Channel: BIOS Requests ONLY!
- Loading...
