MBP 15 2018 A1990 Water damage
  • David82827372
    • Aug 2023
    • 10
    • Kyrgyzstan
    Here's what happened: water entered the connection between the screen and keyboard of my MacBook Pro. The power button has stopped functioning. I have to resort to using the charger to turn on the MacBook.
    Furthermore, even when connected to the charger, it's challenging to turn it on, as after about a hundred attempts, the MacBook starts charging from one of the ports and only then powers up. I've changed outlets and cords, yet it seems like the MacBook randomly chooses when to recognize the charging.
    After several hours of inactivity, the MacBook cannot be quickly turned on by opening the lid. Instead of a swift startup, the Apple logo appears, and the boot-up process is akin to turning on the MacBook after a prolonged power button press.
    Additionally, in the battery settings, a message "service required" has appeared.
    But now MacBook doesn't boot up anymore.
    USB C meter shows stable 20v and unstable low amount of current like 0.003A-0.129A.
    I cleaned come corrosion but some really small amount is still around capacitor CA903, I could not clean it totally with isopropyl and cotton buds. Also I located only 2 very small corrosion areas.​
  • Ugur87
    MacBook Air M4 A3240 Brand New Water Damage no Image
    by Ugur87
    I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
    08-28-2025, 01:09 PM
  • envym
    by envym
    Hi everyone!
    06-27-2025, 08:54 AM
  • TimSinger
    MacBook Pro M4 16" A3403 on the table with water damage
    by TimSinger
    Hi guys,
    I have a MacBook Pro M4 16" A3403 on the table with water damage. I allready found the problem within a bad cap. As far as my researh went, I couldn't find the schematics and boardview for this MacBook model. They seem not to be released now. So my question is if anybody has a working A3403 on the table and could tell me, which specification this capasator has?
    I attached a photo of the missing cap. It's on the bottom side of the logicbard.
    I am very thankful for your replys.
    Thanks in advanced and best regards from Hamburg Germany...
    07-13-2025, 11:12 AM
  • robka
    MacBook Pro 2018 - A1990 Dead - not charging - only 5V
    by robka
    my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
    I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
    The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
    After that the Macbook was dead. It isn't charging anymore.
    The USB-C Port where the charger was plugged is burned. Also The Cable and the...
    03-02-2024, 02:58 PM
  • dbuergi
    Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
    by dbuergi
    i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
    Any ideas where to look?...
    11-07-2024, 10:57 AM
