Macbook Pro M1 A2338 - how to test for 20V?
  • jkruns
    • Mar 2024
    • 35
    • Netherlands
    I have a stack of liquid damaged A2338's, most of which don't draw more than 5v and thus won't turn on.
    So far I've put back the main boards back after cleaning and repair attempts and connected every single component before testing. This obviously take a huge amount of time.
    My question is (maybe not limited to A2338 boards): what's the bare minimum that needs to be connected in order to test if it will draw 20V? Should it draw 20V without the battery connected?
  • tomtom67
    • Mar 2021
    • 14
    I always test for 20V with the bare board, so nothing needs to be connected but the USB adapter. Some models need battery and/or trackpad connected to fully boot though.
    In FlexBV / OpenBoardData there is one solution/checklist available to ease in 20V startup debugging.
    Just had a Coke bathed A2337 here that put up a fight; turned out there were two tracks disconnected and a bad resistor in the ISL area, plus both double-mosfets (Q5230, Q5240) were blown.
    • jkruns
      • Mar 2024
      • 35
      • Netherlands
      Thank you for that!
      With regards to FlexBV, would you say it's worth the investment just for the solution/checklist?
      • tomtom67
        • Mar 2021
        • 14
        As gar as i know even the free version has openboarddata integrated, so you may be fine with it. But as sattes on his web site, the first two jobs will pay the license fee, plus i wanted to support PLDs work. I mean it’s not much money compare to other tools, and well worth it.
        • reformatt
          • Feb 2020
          • 1495
          The butterfly mode (where it shows both sides of the board simultaneously and the connection lines between nets between the two) is a real time saver. The integration between selecting a component on the boardview and auto selecting it (or at least searching each instance) in the schematic is huge.
          If you are doing frequent board repairs, it pays for itself just in the time you save. The Openboard data is a bonus. Paul has done amazing work on this and should be rewarded for it.
          • Orux
            Macbook Pro M1 A2338 13"
            by Orux
            I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
            I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
            One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...
            09-22-2025, 12:54 PM
          • sdogs
            macbook pro M1 a2338 no video on internal display PP3V3_S2 short
            by sdogs
            Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
            First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
            I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
            06-27-2025, 01:58 PM
          • sdogs
            by sdogs
            06-27-2025, 11:26 AM
          • modtool
            Macbook Pro A1989 fallen, reboots if touchbar connected
            by modtool
            Hi to all,
            the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
            Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts...
            11-10-2023, 07:42 AM
          • User555111
            A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
            by User555111
            Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
            02-05-2024, 08:16 AM
