FX516PR not charging on DC charger (but charging on Type-C)
This topic has been answered.
  • pc_okay
    • May 2022
    • 241
    • FRANCE
    Hello friends,
    I have this board not charging with charger, working fine on battery and type-C charger.
    Here what if found: my IC chip miss VCC so i follow the line P_CHG_VCC_30 (0V) to P_CHG_VCC_R_30 (0v) and i get 20V A/D_DOCK_IN.
    I loose my 20V on the PQ9009, i think it's dead because it's a P-Channel and I get 0V on gate and 20V on source and finally 0V on drain.
    Am I right?
    Links for shematics and boardview: https://www.badcaps.net/forum/troubl...s-tuf-dash-f15
    Please find attach IC voltage and the circuit that i think is problematic.
    Thanks !
  • Answer selected by pc_okay at 10-21-2024, 05:27 AM.
    mon2
    • Dec 2019
    • 14543
    The measurements are very low for a good mosfet. Replace the part.
    As a test, flux and remove this mosfet and then bridge the source / drain pins (2 & 3) to allow for the voltage pass through. The OVP feature will be lost but will be safe as long as the adapter voltage is ~20v or under.
    When the mosfet is off the board, test the mosfet in the same way when it is on your work bench. Each posted measurement is too low for a good mosfet.
    • mon2
      • Dec 2019
      • 14543
      Remove all power. Measure the resistance across this same mosfet.
      Source & drain
      source & gate
      gate & drain
      post each measurement. Yes, it appears that this P-channel mosfet is dead since gate voltage is low enough to enable and allow for the pass through from source / drain pins.
      • pc_okay
        • May 2022
        • 241
        • FRANCE
        Source & drain 30 kOhms
        source & gate 300 Ohms
        gate & drain 40 kOhms
        Thanks.
        • mon2
          • Dec 2019
          • 14543
          • pc_okay
            • May 2022
            • 241
            • FRANCE
            Thanks, i'll change the mofset directly when i'll recieve those mofset.
            I don't want to take any risk because the board is actually working with type C... 😁
            Hope that will work !
            • pc_okay
              • May 2022
              • 241
              • FRANCE
              So finaly i change the mofset, i plug charger and.... I heard a little "CLICK" oh that's weird !
              Charger was still not working... I try with another one and again "CLICK" ok, something defintly wrong ...
              I remove the diode and take my measurement and there was a short on the drain ! my bad, i didn't check after removing the mofset.
              After replacing the defect caps and the diode (for the 3rd time) everything works perfectly !
              Thank you again Mon ! πŸ˜ƒ
              • flat-earther
                ASUS X54H laptop thinks it's always charging even with charger unplugged
                by flat-earther
                The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                Windows also shows ''Plugged in'' when charger is not connected.
                This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                If I let battery run out and say it has 3% Windows will...
                06-24-2025, 09:32 AM
              • flat-earther
                how to prevent a connected charger from draining battery when not charging?
                by flat-earther
                I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                So the battery is backfeeding the charger and being drained.
                How can I prevent...
                08-07-2025, 01:04 PM
              • Thomasraud
                Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                by Thomasraud
                i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                QUOTED
                -It works on charger (without battery connected-only charger)
                -It works on battery (without charger connected-only battery)
                -& it also works when plugged in battery & charger, but it's not charging the battery
                //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                and..
                QUOTE
                The IC cannot maintain the input current level
                06-28-2022, 06:47 PM
              • dimis1975
                Macbook A1466 2014 not charging with macsafe 2 charger
                by dimis1975
                I have a macboook air a1466 that stopped charging the battery.
                BAT PINS: with or without ADAPTER IN
                1- GND
                2- GND
                3- GND
                4-0V sense pin
                5-3.42V
                6-3.42V
                7- 8.4V
                8- 8.4V
                9- 8.4V
                AC Adapter plugged in: after a lot of of hours some times start charging
                No BAT Connected- Green to Orange
                AC Adapter plugged in: BAT Connected- no light
                The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
                Any ideas what’s wrong please?...
                08-05-2025, 03:43 AM
              • coasterghost
                Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                by coasterghost
                For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                System Hardware:
                Processor: AMD Ryzen 7 PRO 5850U
                Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                09-08-2025, 10:46 PM
