iPad 8 Wi-Fi 820-02113
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    some kind of nightmare. Help me figure it out! I'll attach a video. Water spill. I cleaned everything. I changed the display and sensor but it didn't help.
    https://youtube.com/shorts/v590x4vJe...6OoxL2-UummLhT
    https://youtube.com/shorts/v590x4vJefY?si=uY6OoxL2-UummLhT
  • GeirAndersen
    iPad .pcb file collection
    by GeirAndersen
    I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
    Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
    IPAD COLLECTION 1
    +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
    +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
    +---iPad mini3 820-00008(A1599) 820-00002(A1600)
    +---iPad mini4 820-00180(A1538) 820-00177(A1550)
    +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
    +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
    12-09-2024, 09:28 AM
    Apple iPad Mini WIFI & 4G Schematic
    Apple iPad Mini WIFI & 4G Schematic...
    10-21-2024, 03:47 AM
  • ApplePie14
    water-damaged iPad 7
    by ApplePie14
    iPad 7 won't turn on.
    When I connected the DC power supply and turned on the switch, the current rose to around 70 mA, then dropped to 0 mA, and then rose again to around 70 mA, repeating this cycle.
    The voltage was normal, including the secondary voltage.
    Could the cause be the CPU?
    08-20-2025, 03:59 AM
    20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
    I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
    At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
    Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
    04-09-2023, 08:04 PM
  • howardc64
    M557-G0 no WiFi/Bt no WIFIVendor file?
    by howardc64
    Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
    • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
    • Service Menu shows many Bt/Wifi info missing
    • Vizio app shows no WIFIVendor file
    Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
    • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
    10-15-2024, 01:12 PM
