No short but PPBUS_G3H missing 820-01700
  • Comp_Pro
    • Jun 2020
    • 33
    Hello all,
    I have this 820-01700 board which came in with 5V 0.015A on the ammeter. Ammeter cycles every 5 seconds or so. Upon inspection I found PPBUS_G3H is reading around 0.6V. There is no short to ground. Diode mode reading is about 0.420V. When I remove fuses F7000 and F7001 the U700 side of the circuit produces 12.3V and the cycling goes away on the ammeter but still stays at 5V and now reads 0A. This goes away as soon as I put back the fuses. I tried injecting voltage onto the system side of the fuse pads but I do not get any current draw at all. I tried seeing if the voltage I was injecting would show up on any of the CPU inductors but it does not.
    PP2V5_NAND_SSD0 read about 0.068 diode mode to ground on one occasion but then went back to reading 0.340
    PP0V9_SSD0 reads 0.337
    PP1V8_SSD0​ reads about 0.340
    Any other things I could check? Very tricky issue since I can't seem to get a reading on whatever short there is or appears to be. I read a similar post where someone suggested checking DFU but would that actually be an option considering we don't even have PPBUS_G3H? Would that be worth looking into?
  • mon2
    • 14631
    Flux and remove C9586. Then test again with the fuse installed.
    • Comp_Pro
      • Jun 2020
      • 33
      Figured out the issue.
      I noticed that when I powered it on this morning I briefly got 20V but was stuck at low current, current was 30mA IIRC. This was after removing C9586 but the capacitor was not shorted and didn't seem to be the cause of the change in behavior. While the charger was still giving me 20V i measured PPBUS_G3H and found it was at 12.3V. After a short while I lost 20V at the USB-C port again and it went back to 5V and cycling. The issue appeared to be related to temperature. Even though I did not get back 5V the ammeter would stop cycling if I warmed up the board. I measured PPBUS_G3H again and found that the voltage here was varying anywhere between 0.6V to 5V.
      I re flowed the charge IC U7000 and it solved the issue! It appears that the PPBUS_G3H 12.6V was disappearing not because of a short downstream but rather it was simply unable to maintain the voltage under load. This is why when I would remove the fuses the voltage would come back and disappear when I would put back the fuses.
      Thanks for the help!
      • Stephen
        MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
        by Stephen
        I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
        02-06-2025, 12:03 PM
      • adelfr2009
        HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
        by adelfr2009
        I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
        After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
        09-28-2025, 10:21 PM
      • khj
        a2337 PP5V_S2 missing no short.
        by khj
        I have a a2337 m1 MacBook Air that has no power.
        PP5V_BSTLQ_SPMU is shorted so I fix it by change cap, coil, u7700. now normal voltage.
        when I didn't connect battery , plugged in power, there is only 5V 0.25a.
        so I checked every power rails , I finally founded PP5v_s2 is 0v, but there is no short.
        PPBUS_5VS2_VIN = 12V normal
        P5VS2_EN from U8100 = 0.6V maybe normal
        P5VS2_FB,PGOOD,VC,SS,BIAS,INTVCC = very low voltage maybe abnormal.
        what should I do ?? do I need to change uc300?
        12-06-2023, 07:00 AM
      • Victor Moreira Silva
        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
        by Victor Moreira Silva
        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
        Well, my decice specs are the following:
        Model: Acer Nitro 5 AN517-54-55T5
        CPU: Intel Core i5-11400H
        GPU: NVIDIA GeForce GTX 1650
        Motherboard: GH51G LA-L181P Rev:1c
        The symptom:
        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
        05-26-2025, 10:49 AM
      • aaronkatrini
        Help me find the short circuit on this WORKING Nvidia GTX1650
        by aaronkatrini
        Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
        Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
        04-18-2024, 03:15 PM
