Another Dell XPS M1730 with failed GPU, but this one is different.
+ More Options
Posts
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Another Dell XPS M1730 with failed GPU, but this one is different.
    I haven't yet damaged any board due to leftover epoxy. Sometimes it does remain in some places, yes, and makes lifting the chip harder. It also makes a mess when you clean the board with the soldering iron and braid, and takes a lot of cleaning to get it off, but that's about it.
    A working TV? How boring!
    • tomodachi
      • Apr 2012
      • 597
      • Turkey
      Yeah, you are definately right. And practice makes perfect
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
      • SSBDADC234
        MacBook Pro 14". The screen DP chip failed.
        by SSBDADC234
        When replacing the screen of this MacBook model, the DP855A chip must be moved from the existing screen for the screen to operate properly.
        However, when I removed the DP855A chip from the existing screen, I must have done something wrong and the chip broke.
        Testing the chip pins with a multimeter revealed a short circuit inside the chip.
        Is it impossible to repair this? I couldn't find a programmer for this chip, nor any eeprom programmer software.​...
        04-19-2024, 08:51 PM
      • BMCappelletti
        Asus Chromebox CN62 - wrong chip put on BIOS reader
        by BMCappelletti
        Long story short:
        - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
        - gave the computer to his son a couple years later
        - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
        - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
        (seems like the story was not that short)
        He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
        01-08-2025, 07:27 PM
      • Troystain
        Help EZP2023+ updated chip database for w25q256jveq?
        by Troystain
        Hello, anyone here have updated ezp2023+ chip database in .dat file format.
        I need to add w25q256jveq chip but I do not know what data should I type.
        I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
        The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
        11-25-2024, 12:53 AM
