Lenovo Flex 5 self power on no post
  • koby058
    • Jan 2017
    • 387
    • israel
    Hi Everyone,
    Lenovo Flex 5-14IIL05 Laptop (ideapad) - Type 81X1
    Laptop powers on however blinking power light and caps lock and esc key lit.
    I have tried a clean bios and also replace the bios chip and got same results.
    When connecting to power supply it pulles nearly 1 amp steady, fan is spinning cpu getting worm no post
    Any advise ?
  • reformatt
    • Feb 2020
    • 1488
    If there is no apparent corrosion or damage to the board, and your Vcore voltages are correct, I usually find this is bad CPU contact due to broken balls etc. I see this a lot on the flimsy lappies which allow the board to flex when you open the lid etc.
    To confirm, try applying pressure to the CPU in different spots with the heatsink off while monitoring current when its beginning to boot. If you see variations up and down, rather than a static figure, then the board is probably booting (use a Chipmunk USB tester or similar is helpful to see if the port is being probed from a booted system). If you need to reball, I'm told the black glue that Lenovo uses makes these chips almost impossible to get off without destroying pads etc.
    • koby058
      • Jan 2017
      • 387
      • israel
      Thanks for your answer
      Will a re flaw work ?
      • reformatt
        • Feb 2020
        • 1488
        Not sure if it has that black glue on the edges. I've never personally tried to remove it, but others say it's awful.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • claws77
          lenovo flex 5 14itl05 power sequence issue
          by claws77
          hi guys, my motherboard will not start no matter what
          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
          but rest nothing happens no sign of life.
          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
          i have no knowledge of motherboards ....
          10-20-2024, 02:48 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • survivalbloke
          Lenovo Flex 5 14ITL05 - will only sleep if commanded to through start menu>power icon
          by survivalbloke
          This laptop refuses to sleep unless specifically commanded to sleep through Windows. If I close the lid, the screen does go dark just before the lid is closed, so it appears the hall sensor works. However, it will sit there, drawing 1.xx amps until the battery dies. If I command it to sleep, it drops down to normal sleeping current. If I have it sleeping with lid closed and I disconnect the power adapter, it will wake from sleep, even with the lid closed. I have updated the firmware, but still the fault persists. I've also verified power settings in Windows that the device is to sleep when the...
          03-20-2025, 02:29 PM
