Help identifying Cap
  • drdyzio
    • Apr 2014
    • 74
    Hey guys trying to find a replacement for this
    its of an acer aspire one
    And Can maybe someone please tell me how can this get damaged?
    Im not sure if its externally damaged.
    Thanks guys
  • kotnatan
    Banned
    • Apr 2014
    • 181
    • Ukraine
    Re: Help identifying Cap
    what motherboard?
    • kotnatan
      Banned
      • Apr 2014
      • 181
      • Ukraine
      look this https://www.badcaps.net/forum/showthread.php?t=37109
      • drdyzio
        • Apr 2014
        • 74
        its a d250 , kav60 la- 5141p
        did get some help that other thread.
        Thank you!!!
        • unimatrix93
          Identifying component Flyback? DC-DC?
          by unimatrix93
          Can I ask you guys help me identify this godforsaken component?
          I'm tearing my hair out finding this component.
          The board is from an egg incubator.
          i got it with a "popped cap" while there are many damaged components on it, which got succesfully identified with one exception:
          And here is the board where it came from (U1/1):
          As you can see, the IC is badly damaged. Only a few characters are visible and a unknown by me manufacturer logo. Also it has 3 pin on the top side.
          Can you please help me find out what is i...
          05-08-2024, 08:21 AM
        • gurj1979
          Seagate IronWolf NAS 8tb - blown component
          by gurj1979
          Hi guys, not sure if Hard Drive questions are meant to be in here, but Admin feel free to shift to correct location.
          I need help identifying a blown SMD component on this Seagate IronWolf NAS 8TB.
          See image for component location. You can clearly see the damaged component.
          I'm guessing its AGKH, can anyone verify or have a link to Datasheet ?
          Thanks....
          07-22-2024, 06:32 AM
        • Tomylee
          Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
          by Tomylee
          I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
          It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
          I'm looking for help with the following:
          The exact identification or part number of the T5 component
          05-28-2025, 12:42 PM
        • tofik
          LG 50PA6500 Plasma TV damaged after a power spike
          by tofik
          Hello, I have an LG 50PA6500 Plasma TV, purchased new in 2012.
          Unfortunately plasma is not working at all after a power spike.
          Qucikly tested the PSU and voltages seems to be okay, when eveything is disconntected from the PSU I got:
          VS = 200-206 / actual = 205 V,
          VA = 55 / actual = 54.9 V,
          M5V = 5.2 / actual = 5.19 V,
          17 = 17.24 V,
          5.2 = 5.19 V,
          STDBY = 5.19 V,
          ERROR_DET = 4.8 V - does it mean PSU is damaged? the rest of the voltages seems to be fine.
          what's your opinion about the PSU?
          Also I just...
          12-20-2022, 03:08 PM
        • phantomEVO
          [help]820-01521 WATER DAMAGED
          by phantomEVO
          HELP! audio board+its flex+powerbtn flex water damaged (an hole on audio board)!!! chnged both, but i have 5v on both ports:
          https://files.fm/f/6gjpqyjw3q
          here some measurements
          ppbus_g3h 12,29v
          PP3V3_G3H 3,29v
          pp3v3_upc_xa_ldo pp3v3_upc_xb_ldo 3,27v
          PP1v8_UPC_XB_LDOD PP1v8_UPC_XA_LDOA 1,8v
          PP1v8_UPC_XA_LDOD PP1v8_UPC_XA_LDOa 1,8v
          PP1V1_UPC_XA_LDO PP1V1_UPC_Xb_LDO 1,1v
          with battery connected, as soon as i connect the cable, i see direclty 20v, but stuck at 0,0250
          10-24-2025, 04:23 AM
