Toshiba 55LWH - Turn off on battery
  • borbooroski
    • Mar 2014
    • 177
    • Ghana
    I have this Toshiba Laptop which my Boss gave me, is Toshiba Dynabook EX/55LWH i3 processor.
    If it is on with the Adapter it will work fine but if I add the battery then it will turn off I did all I could but still not ok. Please Guys I need your help please help me. Thank you all
  • borbooroski
    • Mar 2014
    • 177
    • Ghana
    Re: Toshiba 55LWH - Turn off on battery
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • fauzanmint
      Chromebook can't turn on without a normal battery
      by fauzanmint
      I have several chromebook laptops, the problem is that the battery is damaged. I tried to buy 1 and I tried on all off units can turn on normaally. This means the Chromebook can't turn on without a normal battery.
      is there a way to turn on a chromebook without a battery with bios or hardware modifications?​
      10-12-2024, 02:36 AM
    • huzo
      HP ELITE X2 1013 G3 weird battery issue
      by huzo
      Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
      01-31-2025, 12:09 AM
    • trepachka
      iPad Air A1475 Boot loops after replacing battery
      by trepachka
      This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
      The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
      I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
      11-08-2024, 03:17 PM
      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
      Narrow VDC applications where the system power source is
      either the battery pack or the regulated output of the charger.
      This makes the max voltage to the system equal to the max
      battery voltage instead of the max adapter voltage. Operating
      at lower system voltage can improve...
      11-05-2024, 04:43 PM
