Vaio VPCSB2M9E/PCG-41218M dead after drop
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    #41
    Re: Vaio VPCSB2M9E/PCG-41218M dead after drop
    I didn't. I confirm, F1 is blown in my board too. Thanks.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
    • atsio
      • Oct 2013
      • 819
      • Greece
      #42
      Your initial problem was that the charger wasn't sending ACOK signal to EC IC. Probably you created a short on the 19v line and blown the fuse.
      The short is still there because you have a short on pins 19 and 20 of charger IC
      • Learn2Day
        • Jun 2013
        • 254
        • Portugal
        #43
        The short on 19v line was coming from the main board, solved after replacing shorted capacitor. This is what probably has blown the fuse. I no longer have a short between pins 19 and 20 but ever since it occurred, I have sparks coming from image markings.
        Try Harder!
        • atsio
          • Oct 2013
          • 819
          • Greece
          #44
          What do you mean with "image markings"?
          • atsio
            • Oct 2013
            • 819
            • Greece
            #45
            If I understand correctly, sparks on pins 19,20 of charger and the 2 resistors. Can you post pictures from the top but clean thoroughly the area before doing that?
            • Learn2Day
              • Jun 2013
              • 254
              • Portugal
              #46
              I have those pics in my earlier posts. Yup, you understood correctly.
              Try Harder!
              • atsio
                • Oct 2013
                • 819
                • Greece
                #47
                I needed an new clean one to see the lines of the two resistors. Did you solder the charger ic with hot air or hot iron?
                • Learn2Day
                  • Jun 2013
                  • 254
                  • Portugal
                  #48
                  Hot air, I can't even imagine soldering such a tiny IC with a iron. Can't go back in time to get a clean photo, sorry. Don't feel bad atsio, I do assume I still make mistakes. In this case, I might have bitten more than I could chew soldering such a tiny IC in such a crowded board.
                  Try Harder!
                  • atsio
                    • Oct 2013
                    • 819
                    • Greece
                    #49
                    With all IC's, if I solder them by hot air, in the end I use the iron to be certain that the connections to the pads are solid
                    • BTubbs200
                      Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                      by BTubbs200
                      Dell Latitude 5420 P137G
                      Board: LA-K491P REV A01
                      I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                      Board seems to have no shorts, all power rails are fine and show high resistance.
                      When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                      01-24-2025, 08:15 PM
                      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-06-2024, 05:27 AM
                      Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                      This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                    • flat-earther
                      how to prevent a connected charger from draining battery when not charging?
                      by flat-earther
                      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                      So the battery is backfeeding the charger and being drained.
                      How can I prevent...
                      08-07-2025, 01:04 PM
                    • flat-earther
                      ASUS X54H laptop thinks it's always charging even with charger unplugged
                      by flat-earther
                      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                      Windows also shows ''Plugged in'' when charger is not connected.
                      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                      If I let battery run out and say it has 3% Windows will...
                      06-24-2025, 09:32 AM
