Hi, I think to buy a Frequencymeter for my workshop. Do you think it is important tool to have? Does somebody use it to detect and solve some problems? I think to buy Victor VC3165. Do you know something abut this Frequencymeter?
Frequencymeter is it need to repair laptop?
Re: Frequencymeter is it need to repair laptop?
http://www.wikihow.com/Choose-an-Oscilloscope
http://www.picotech.com/applications..._tutorial.htmlComment
Yeah get an oscilloscope instead, which is very useful, and you can use the oscilloscope to measure frequency anyway.
A high precision frequency counter is needed to precisely measure\calibrate some things, but in a laptop if you have say a 33MHz clock, all you need to know is that it's close to 33MHz or something totally wrong like 20MHz, and you can tell that easily with an oscilloscope, you don't need the frequency counter.
That said... you can get frequency counters that go to high frequencies much cheaper than you can get an oscilloscope... but most of the time you wouldn't use one.
Bandwidth is only 1MHz on those things, useless for high speed digital."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
Oscilloscopes are instruments with high sensitivity, therefore are capable to measure frequency and voltages or waveforms at 2mV and above.
Frequency counters have higher trigger voltage (example 200mV) and common multimeter have even higher trigger voltage (so their frequency counter to start shown frequency).
On laptops and motherboards the frequency crystal is powered with about 120mV , only one oscilloscope it can measure this due it high sensitivity in low voltages.
Regarding oscilloscope bandwidth the rule of thump is the oscilloscope to be five times faster than the signal that you need to measure.
In my case I wanted measurements up to 20MHz, and selected my oscilloscope at 100MHz.
50MHz is very common size of bandwidth for fresh oscilloscope's, if you wish saving some money just buy one with two channels.Comment
Could you not just use an amplifier on the counter's input then?Frequency counters have higher trigger voltage (example 200mV) and common multimeter have even higher trigger voltage (so their frequency counter to start shown frequency).
On laptops and motherboards the frequency crystal is powered with about 120mV , only one oscilloscope it can measure this due it high sensitivity in low voltages."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
Nice question coming by simplified human logic.
I am not aware of such broadband preamplifier capable for 60Hz up to 6MHz, that is the range of most commonly used in applications crystals.Comment
Good point. But hey, I never said I was an expert..."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
By getting one Oscilloscope and learn how to use it, for a period of six months,
It will awake or unlock your imagination of where it can serve you.
For the ones who do not have a true technical education background, they should better buy one guitar instead.Comment
This part of the Forum "Troubleshooting Laptops & Notebooks" was started by members that knew next to nothing about laptops, they only wanted to learn, thanks to Top Cat he let them do just that.
Some brilliant minds have come forth to join in since then, and helped the likes of the ill educated like me, the likes of you with your snide remarks we can do without, (you have nothing to contribute except smart ass answers) we don't want them, why are you here, you just want to show how much of a smart arse you are, but your not bright enough to see how much of a a***hole you are.
trebo
and I am sure many members have the same thoughts as me, even the educated onesComment
I can do nothing for the ones which the voice of truth is not serving their purposes.
Simple as that.Comment
By calling as a***hole your teacher in the field no matter what you ask afterwards, you will never get an answer either.
Mentors can give a hand only when you are still in school.Comment
This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...09-06-2024, 09:30 PM
This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-06-2024, 08:47 AM
by RdeveLabsTo all the members here...
Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But... -
This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-07-2024, 06:11 AM
- Loading...
