Frequencymeter is it need to repair laptop?
  • MDY
    • Jan 2014
    • 75
    • Spain
    Hi, I think to buy a Frequencymeter for my workshop. Do you think it is important tool to have? Does somebody use it to detect and solve some problems? I think to buy Victor VC3165. Do you know something abut this Frequencymeter?
  • khaahk
    • Dec 2013
    • 815
    • Estonia
    Re: Frequencymeter is it need to repair laptop?
    Don't see any use for such a device. Would buy a used oscilloscope instead. Or gather little more for new one. Even oscilloscope is rarely needed, from personal experience.
    • atsio
      • Oct 2013
      • 819
      • Greece
      You need a counter to measure clocks. Of course is better a DSO (which you can use and as a counter), which can help you to compare signals - signal strength.
      • MDY
        • Jan 2014
        • 75
        • Spain
        I found this DSO very cheap Mini DSO201 PRO
        Do you think it is good to measure clocks or it is better Victor VC3165?
        • atsio
          • Oct 2013
          • 819
          • Greece
          I don't know your budget, but I would buy an at least 50MHz desktop DSO.
          • MDY
            • Jan 2014
            • 75
            • Spain
            Do you mean to measure up to 50Mhz?
            • atsio
              • Oct 2013
              • 819
              • Greece
              http://www.wikihow.com/Choose-an-Oscilloscope
              http://www.picotech.com/applications..._tutorial.html
              • Agent24
                I see dead caps
                • Oct 2007
                • 5080
                • New Zealand
                Yeah get an oscilloscope instead, which is very useful, and you can use the oscilloscope to measure frequency anyway.
                A high precision frequency counter is needed to precisely measure\calibrate some things, but in a laptop if you have say a 33MHz clock, all you need to know is that it's close to 33MHz or something totally wrong like 20MHz, and you can tell that easily with an oscilloscope, you don't need the frequency counter.
                That said... you can get frequency counters that go to high frequencies much cheaper than you can get an oscilloscope... but most of the time you wouldn't use one.
                Bandwidth is only 1MHz on those things, useless for high speed digital.
                -David VanHorn
                • Kiriakos GR
                  Banned
                  • May 2012
                  • 940
                  • Greece
                  Oscilloscopes are instruments with high sensitivity, therefore are capable to measure frequency and voltages or waveforms at 2mV and above.
                  Frequency counters have higher trigger voltage (example 200mV) and common multimeter have even higher trigger voltage (so their frequency counter to start shown frequency).
                  On laptops and motherboards the frequency crystal is powered with about 120mV , only one oscilloscope it can measure this due it high sensitivity in low voltages.
                  Regarding oscilloscope bandwidth the rule of thump is the oscilloscope to be five times faster than the signal that you need to measure.
                  In my case I wanted measurements up to 20MHz, and selected my oscilloscope at 100MHz.
                  50MHz is very common size of bandwidth for fresh oscilloscope's, if you wish saving some money just buy one with two channels.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5080
                    • New Zealand
                    Could you not just use an amplifier on the counter's input then?
                    -David VanHorn
                    • MDY
                      • Jan 2014
                      • 75
                      • Spain
                      Question is if I have oscilloscope and make measure to some crystal (SIO, Southbridge), could I make a more accurate diagnosis?
                      • Kiriakos GR
                        Banned
                        • May 2012
                        • 940
                        • Greece
                        Nice question coming by simplified human logic.
                        I am not aware of such broadband preamplifier capable for 60Hz up to 6MHz, that is the range of most commonly used in applications crystals.
                        • Kiriakos GR
                          Banned
                          • May 2012
                          • 940
                          • Greece
                          Just name your age, so to offer you the correct answer.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5080
                            • New Zealand
                            Good point. But hey, I never said I was an expert...
                            -David VanHorn
                            • rtstorm
                              • Feb 2012
                              • 971
                              • Croatia
                              which are other uses the oscilloscope in laptop repair except testing crystals. What else can I test it with ?
                              ...the quieter you become the more you are able to hear...
                              • Kiriakos GR
                                Banned
                                • May 2012
                                • 940
                                • Greece
                                By getting one Oscilloscope and learn how to use it, for a period of six months,
                                It will awake or unlock your imagination of where it can serve you.
                                For the ones who do not have a true technical education background, they should better buy one guitar instead.
                                • trebo
                                  • 514
                                  • Wales, UK
                                  This part of the Forum "Troubleshooting Laptops & Notebooks" was started by members that knew next to nothing about laptops, they only wanted to learn, thanks to Top Cat he let them do just that.
                                  Some brilliant minds have come forth to join in since then, and helped the likes of the ill educated like me, the likes of you with your snide remarks we can do without, (you have nothing to contribute except smart ass answers) we don't want them, why are you here, you just want to show how much of a smart arse you are, but your not bright enough to see how much of a a***hole you are.
                                  trebo
                                  and I am sure many members have the same thoughts as me, even the educated ones
                                  • Kiriakos GR
                                    Banned
                                    • May 2012
                                    • 940
                                    • Greece
                                    I can do nothing for the ones which the voice of truth is not serving their purposes.
                                    Simple as that.
                                    • trebo
                                      • 514
                                      • Wales, UK
                                      good mentors always told me, that I wont learn if you don't ask
                                      • Kiriakos GR
                                        Banned
                                        • May 2012
                                        • 940
                                        • Greece
                                        By calling as a***hole your teacher in the field no matter what you ask afterwards, you will never get an answer either.
                                        Mentors can give a hand only when you are still in school.
                                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                          09-06-2024, 09:30 PM
                                          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:47 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                          Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:11 AM
