LA-3541P No power
  • PlusCom
    • May 2013
    • 50
    • Greece
    LA-3541P No power
    Need some help here guys. PQ11 source and gate voltages is OK 18.8v but 0.47v on drain which is coming from PQ9's source, gate is 19.2v. Already replaced both Fets.
    Thanks.
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: LA-3541P No power
    Gate should be low. That's a P-Channel mosfet. It is locked in protected mode. Check 19V line for short and if charger is faulty.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      If you don't have any short on 19v line and charger measures ok, just strap that MOSFET and call it a day.
      I've seen this issue on multiple boards and it's a royal pain tracing the drive of that fet. I broke a board while tracing such an issue when a wire slipped and shorted the CPU VRM, and ever since i haven't bothered to trace that ever again. This usually happens after a charger with higher voltage is accidentally used with the laptop, and if there are no shorts on any of the power rails, simply jumping that FET will work fine.
      Of course, with that MOSFET bypassed, all bets are off if 24V or something silly is applied again, but that's the user's problem, not yours...
      A working TV? How boring!
      • whaldsz
        • Apr 2013
        • 395
        • Philippines
        what do you get at pin 2 and 3 of PU1A? If pin 1 of PU1A is low you will get 19v at the gate of PQ11.
        • PlusCom
          • May 2013
          • 50
          • Greece
          Thanks a lot guys for the answers.
          PU1
          pin1 3.19v
          pin2 3.33v
          pin3 3.67v
          • ivanxxx
            • Nov 2012
            • 10
            • Croatia
            On those boards, its very common to have a capacitor failure. Chek all capacitors for shorts, you can pull out the inductors Pl4 PL14 PL9 Pl17, so you can localize shorts.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
              03-31-2024, 02:12 PM
              09-06-2024, 05:59 AM
