Replacing 216-0774008 to 216-0774009
  • jeremykum
    • Feb 2012
    • 95
    • Malaysia
    I am just trying my luck here if there is anyone here tried this and had success.
    Laptop CQ42
    DA0AX1MB6F1 REV:F
    Original fitted chip is 216-0774008, since I had ran out of this exact chip, I fix a 216-0774009. Both chip are same series HD5470, same design as well.
    Originally, I had IR reflow the 4008 but only lasted about 1 month before it died again. Hence no other choice but to replace it. Before I fix up the 4009, I did tried a short 20 second hot air reflow, and the board booted up again. (just to confirm the chip is giving problem).
    Now with the 4009, standby is normal 0.010A, can start up when press the power button, yet I am not getting display.
    Had anyone tried this on this particular board and chip and had success?
    I understand this sometimes the board/BIOS accept the substitute chip (I am not familiar with BIOS mod though).
    Had tried yesterday with a Compaq 6535b, 6050A2213604-MB-A03, original chip 216-0674022 replace to 216-0674026 and works fine.
    If you are wondering why didn't I just replace the same chip, well it takes time for me to order from China, and it's a problem for me to stock so many types of chips. Yet this customer need to use the laptop asap.
    I am at the moment trying to compile a list of substitutes chip/mainboard from a russian speaking forum, and if anyone here interested to share info and build the list, I am very grateful. Can email or PM me. Once enough I will share it here for those who repair laptops.
    Mainly repair laptops, sometimes LCD/LED monitors. Also accepts changing/reballing/reflow BGA job request.
  • djromann
    • Sep 2013
    • Italia
    Re: Replacing 216-0774008 to 216-0774009
    You have to modify the BIOS for get it functional
    • lefos
      • Nov 2013
      • 321
      • Greece
      I wanted to ask you if the opposite procedure will work? I have a dell motherboard with originally installed 216-0774009, and in stock I have 216-0774008. Dο you think that it will be compatible? Has anyone succeed in this change?
      • forespec
        • Nov 2012
        • 14
        • India
        Did you try interchanging these ics lefos? If yes please let us know if it worked. Dell 1558 has ATI 216-0774009. Does anybody know if ATI 216-0774008 from cq 42 is compatible. Thanks
        • rager007
          • Feb 2016
          • 106
          • Usa
          • tujuhkalitujuh
            • Oct 2013
            • 27
            • Indonesia
            I ve done this before and ended up with no display on my dell
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
              Common SPI bios chip programming Questions and Answers
              by SMDFlea
              Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
              A: If you can`t read from it how do you expect to write to it ?.
              Q: Why is my bios chip unreadable ?.
              A: The programmer is faulty or has a worn or broken zif socket.
              The USB cable is frayed,connector pins worn or some other physical damage.
              Not enough amperage or voltage to power the programmer properly.
              Bad...
              09-02-2021, 04:40 PM
            • BMCappelletti
              Asus Chromebox CN62 - wrong chip put on BIOS reader
              by BMCappelletti
              Long story short:
              - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
              - gave the computer to his son a couple years later
              - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
              - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
              (seems like the story was not that short)
              He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
              01-08-2025, 07:27 PM
            • barbas
              Replacing BIOS Windond chip, present in MSI GE78HX laptop for and MXIC and what is Quad SPI
              by barbas
              Hi. In the process of troubleshooting an MSI GE78HX laptop that does turn on (on its own), turns on the backlight on and off in infinite cycle, turns on RGB keyboard backlight and light bar. The CPU gets hot, and its fan spins.
              The laptop charges the battery, turns on charging lights, which leads me to think the EC (ITE5571E) is ok. Laptop has no shorts, apparently. Memory is ok, tried it in another machine. Tried 5 different sticks in this machine as well, does the same. Memory connector seems ok, no pins bent.
              First, I am going to try to backup and reflash its BIOS,...
              05-14-2024, 02:01 AM
