laptop freezes, usb 2.0 not working, usb 3.0 working
  • bociub
    • Dec 2023
    • 32
    Hi there,
    It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
    Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what have usb 3.0 then that works perfectly. Comparing the two usb A socket and their related componenets with a multimeter I did not found any difference. If I try to run 3dmark always freezes during the test.
    Can it be more strange? If I connect an usb 3.0 stick to the working usb-a socket before powering on then the webcam, mic works. If I remove it the cam and the mic wont work anymore even if i plug back the stick. No freezing at all! and still something in the device manager which not working on usb. 3dmark runs perfectly again and again. Furtheremore, If I unplug the usb 3.0 stick and I connect and usb 2.0 one then that also works perfectly.
    Any idea?
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    is the voltage too high on usb ?
    • mon2
      • Dec 2019
      • 14220
      Remove all power / no battery. Meter in DIODE mode. Red meter probe, yes red to ground. Black meter probe to point to test.
      Test the D+ signal of this socket in diode mode.
      Test the D- signal of this socket in diode mode.
      Post each measurement. Nearby, on quality laptops, will be an ESD protection device for each such port. It is possible that the ESD diode is now defective from the last event and therefore shunting the USB 2.0 signals to ground or causing them to fail. Post pics of the parts in this region of the board. The ESD devices may be single in nature or perhaps an array (common) where one package protects both the D+ and D- lines and perhaps even VBUS.
      • bociub
        • Dec 2023
        • 32
        5.111 volts. Very stable. Is it too much?
        • bociub
          • Dec 2023
          • 32
          Thanks. So the 4 pins in diode mode are : 0 , 0.487 , 0.491 and 0.585. Are the middle two d+ and d-?
          Sadly, there are not too much things. All lines are disappearing in the pcb. There are 3 three legged transistor like things only on the other side, otherwise the board empty.
          • bociub
            • Dec 2023
            • 32
            Some update as I wasted same time again on a horrifying hobbi what i love: I removed the board again to make some nice picture with my microscope and I also tried the board without anything connected... so the battery, an external monitor, memory, ssd were connected and still there is a thing what connected to the usb and malfunctioning according to the device manager. That thingy is on the motherboard but I have no idea what that is, where it is.(picture 1.jpg). Defenetly, not the sound or the lan. Maybe something what is related to the usb-c? How can I find out what that is? When I disabled it I did not lost any functionality(or I could not discover it.)
            If I disable the entire usb controller in the device manager then I was not able to frezee the laptop with 3dmark however if I disable the misteruous usb device then the laptop still frezees sometimes.
            Behind the damaged usb port a diode just fell of by touching it(picture 2 - I melted the solder to make it look nice). It is a three legged thingy with ZJ sign on it and looks like it supposed to short two datalines to the ground. (red circles). Anyway it did not change anything.
            ant idea?
            • piernov
              • Jan 2016
              • 4435
              • France
              USB 2.0 controller is probably detecting that a data line has been pulled up but the device does not answer when queried. USB 3.0 detection mechanism is a bit more complex but I'm not sure if it can show these symptoms.
              Card reader and Bluetooth controller (can be inside Wi-Fi card) can also be connected to the USB bus.
              There are like 10 different USB 2.0 ports going to the PCH, so a lot can go wrong, and of course the USB controller inside the PCH itself could be damaged.
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                have you tried just a usb cable plugged in ?
                • rogfanther
                  • Jul 2006
                  • 458
                  • Brazil
                  Take a better look at these guys. The lower one seems to have something blown on top of it.Click image for larger version
                  • mon2
                    • Dec 2019
                    • 14220
                    The part on the left is a flow through pinout ESD array with a built in zener clamp diode to keep VBUS @ 5 volts (no higher voltages allowed).
                    The part on the right is an EMI filter to suppress the highspeed switching noise created by the USB bus interface.
                    Respectively, flux and carefully reflow the part on the left and remove off the board. Just leave the component off the board for now. Confirm that the PCB pads are not solder shorting using desoldering braid.
                    Then power up and test again. Repeat with the next USB connector if needed. These parts are sacrificial that die after a transient hits the USB connector(s).
                    The parts are < $ 0.10 USD each. We use them in high volume on many of our designs. They work very well.
                    You can purchase replacements from many vendors - we use SOCAY (China) but there is also Texas Instruments who offer drop in parts you can probably source through Digikey / Mouser / Arrow.
                    This part is very likely to be:
                    ULC0524P
                    ULC0524P Leiditech | C384892 - LCSC Electronics
                    TI # TPD4EUSB30
                    TPDxEUSB30 2-, 4-Channel ESD Protection for Super-Speed USB 3.0 Interface datasheet (Rev. G)
                    • szepesif
                      Lenovo Ideapad 3 15IIL05 working perfectly with onboard RAM but it doesn't start when I add a memory into the RAM slot
                      by szepesif
                      Hey guys!
                      I don't know the solution to this problem, but this is definitely not unique and I would like to figure out the solution to fix these in the future.
                      I have two identical Lenovo Ideapad 3 15IIL05 laptops with integrated 4GB DDR4 memory. Both work perfectly with that. BUT... if I add any extra memory to the single RAM slot, it never gives a picture. I thought the RAM slot pins would be the problem but no, all pins are solid (I checked them under the microscope). The RAM in the slot has 1.2V, so the voltage is present on the module. I flashed the latest BIOS, so
                      04-19-2025, 10:18 PM
                    • MMH3
                      Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                      by MMH3
                      i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                      Never ever i experienced problems with that.
                      Now i have one 5050sff machine, where this jumper isnt working at all.
                      I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                      The history of the machine is that i used it in my office...
                      03-23-2025, 09:28 PM
                    • DynaxSC
                      GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                      by DynaxSC
                      I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                      There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                      The board is generally working now, all PCIe ports are working, Windows installs normally.
                      However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                      The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                      03-10-2025, 12:27 PM
                    • obelix24
                      Macbook Air 2020 (a2179) - touch id not working
                      by obelix24
                      Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                      I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                      02-09-2025, 12:57 PM
                    • hopkok
                      Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                      by hopkok
                      Hi masters, I need your help.
                      I am working on Lenovo Legion 16ITHg6
                      Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                      INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                      My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                      AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                      Power LED is not working as well, power button working well.
                      UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                      Motherboard...
                      05-04-2025, 09:35 AM
