Why do laptops start on their own
  • Scootie
    • Feb 2014
    • 133
    Since a few months I dweld myself into some light laptop repairs, mainly reballing and now I also tried out some bios flashings. Btw, I work in at an IT sale store hence the need to try and repair these units. There is still a lot for me to learn, still need to catch the magic of reading laptop schematics.
    My first question for today is: Why do some laptops start on their own the moment when ac adapter is conected to them. I noticed this at quite a few laptops and can't figure out quite why?
    Any ideas where to look for troubles?
    Simptoms for these troubles vary from laptop to laptop:
    - laptop starts up on ac adapter conect but no vga,
    - starts up on ac adapter with vga and performs well and can be shutdown
    and a few other examples but I dont want to bring up that many examples.
  • spleenharvester
    • Mar 2010
    • 903
    Re: Why do laptops start on their own
    Some laptops, particularly Dells, have a start-on-AC option in the BIOS. That's worth checking.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • Scootie
      • Feb 2014
      • 133
      The laptops I've had so far were 3xAcer(5740g, 5735) and 1xHP Compaq 6735s(autostart but no vga) and they didnt have this option in the bios so I assume something is bad in there.
      • lefos
        • Nov 2013
        • 321
        • Greece
        Sometimes low rtc battery voltage might be the problem.
        Also check for any liquid damage on keyboard / media buttons board.
        • spidey
          climbs
          • Dec 2012
          • 644
          • Cyprus
          mostly rtc battery.
          • sasser
            • Dec 2012
            • 364
            • Malaysia
            i got one netbook lenovo s100. connected charger and power on and laptops start on their own without press button. also no display. no current on processor and intel nm10
            • spleenharvester
              • Mar 2010
              • 903
              Hmm, I'd be interested to know if anyone finds anything on this. Maybe KBC fault? Presumably any short on the 3v rail connected to the power button, or anything that stops that 3v voltage being generated, is able to cause an auto power on?
              • chaos-theory
                Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                by chaos-theory
                I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                03-14-2025, 05:37 PM
              • NanoTesting
                Anyone else been having problems with chinese laptops using ESSX8336 / ES8336 audio?
                by NanoTesting
                This audio chipset has been a pain to deal with, most of the time its impossible to find drivers for chinese laptops that have no name/brand, or generic rebranded laptops.
                Huawei also started to use it BUT they no longer host drivers on their website since they want you to force their PC manager app that often refuses to install after bios flashing and apparently the generic drivers around wont work on some intel systems and others wont work on amd systems, the generic ones have worked only once and i think i have had this problem on 30+ laptops so far in the last year.
                02-21-2025, 12:33 AM
              • arabex21
                Asus Prime B450M-A starts only when 12v 8pin cpu plug disconnected
                by arabex21
                Hello everyone. I have been reading this forum for a long time - I really appreciate the amount of very interesting materials and information in the field of electronics.
                I have a problem with this configuration:
                ASUS PRIME B450M-A
                RYZEN 1300X (I replaced it with ATHLON 200GE - the same behavior, the processors are functional, tested on another board)
                When the entire set is installed (CPU, RAM, ATX connector and 12V 8 pin CPU plug), the board starts up for a while (about 1-2 seconds), the CPU fan starts and the board turns off immediately. When I disconnect...
                09-19-2024, 03:05 AM
              • dr.thodt
                Lenovo laptops unstable with sodimm ram
                by dr.thodt
                For the second time this week I received a Lenovo laptop with onboard ram and one sodimm slot. Both laptops run stable from their onboard 4GB RAM, but turn out to be very unstable when there's a sodimm inserted in the slot.
                Both times it was a GS44D/GS54D NM-C711 rev 1.0 board.
                Both times there were no loose pins on the slot and it did not matter what sodimm I put in. It just artefacts and crashes randomly when there's extra ram.
                What I did notice is that almost all coils have very dirty phases one the mosfet side when checked with an oscilloscope. Not something I see very often....
                06-07-2024, 09:16 AM
              • dsmartbox
                Any 11th gen Intel schematics of modern laptops
                by dsmartbox
                Hello Everyone,
                I am looking for schematics of good quality laptops and tablet with 11th gen CPU.
                I'm an engineer and I'd like to study them.
                I can find:
                - Macbooks
                - Surface laptops
                Does anyone have any schematics of 11th gen Dell XPS laptops, or other good-quality premium laptops and tablets?
                it would be much appreciated!
                02-08-2022, 07:28 AM
