HP G62-b10sg does not charge, works with battery
  • Technolix
    • Mar 2014
    • 15
    I am new to this forum and have a problem with an HP G62-b10sg.
    It won't start without a charged battery. When I attach the PSU without an battery installed, the LED of the power switch, short lits up blue and thats it.
    If I start it with a charged battery and its powered on, I can remove the battery and let it run from the PSU.
    The LED left of the power jack does not lit up and the battery will not charge.
    I've tested so far 2 different PSUs, one 18.5 and one new 19V. They are both second brand PSUs. An original HP is on its way.
    I've also tested two different batterys whitch are known as good and they have the same part numbers.
    I've updated to the newest bios and removed the CMOS battery for 15min while pressing the power button 1min. without battery installed.
    I haven't open the notebook yet. Where do I should look?
    I am experienced in soldering and notebook repairs and read all threads about the G62 in this forum but couldn't find a matching topic for my problem.
    I hope someone can help me.
    Thanks in advance for your help.
  • dj_ricoh
    • 2073
    • uk
    Re: HP G62-b10sg does not charge, works with battery
    I saw a g71 like yours.
    I swear I call the guy stupid.
    The notebook actually power but the screen stood black. No boot.
    After you putt back the battery it booted up.
    I was like what the #%@&.
    Open if so at least we can find a schematic and start from somewhere.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5076
      • New Zealand
      Something wrong with the power\charging controller circuitry I expect
      -David VanHorn
      • Technolix
        • Mar 2014
        • 15
        It has been opened by a friend of mine before he gave it to me, who looked for burnt ICs and blown caps but couldn't find anything.
        I am searching now for a defective board with no charging issues to swap the power/charging circuit.
        Most of the HPs use the same battery. Are there differents between main parts of the charging circuit, like different MAX Ics?
        I want to ask because Id like to get a cheap board, lets say from an Dv3.
        • dj_ricoh
          • 2073
          • uk
          we need to focus on ISL6251 page 40
          Pin 24 DCIN
          Pin 2 ACSET(ACIN)
          Pin 23 ACPRN(ACOK)
          you need to check the V there and post here after.
          p.s. see if the diagram its ok!
          • Technolix
            • Mar 2014
            • 15
            I don't have an ISL6251 but an Maxim8731ae witch is an battery charger and indeed its blown.
            Seems my friend hasn't looke close enough.
            My part number of the motherboard is 615381-001
            Do you have a schematic of this board?
            What else do I check?
            • Technolix
              • Mar 2014
              • 15
              okay I've checked the datasheet and removed the Maxim.
              here are my readings:
              DCin Pin22=19,4V
              ACin Pin02=2,66V
              ACok Pin13=0V couldn't figured out what its guess its an output?
              Are the readings okay or is there another fault.
              Regards,
              Michael
              • spidey
                climbs
                • Dec 2012
                • 644
                • Cyprus
                check mosfets also.
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3627
                  • slovakia
                  there are lot of 3pin mosfets that switches the acok signal. must check all off them
                  • atsio
                    • Oct 2013
                    • 819
                    • Greece
                    Give voltages on PQ800 and PQ801 (all pins)
                    • atsio
                      • Oct 2013
                      • 819
                      • Greece
                      I've just noticed you checked pin 13 of charger. Probably you need to replace charger. Desolder first PR823, PR826 and PR827 and check again pin 13 of charger. Check also pin 3 of charger for REF voltage.
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        You 've checked pin 13 with charger removed?
                        • Technolix
                          • Mar 2014
                          • 15
                          sorry for my late reply.
                          I've replaced the Maxim charger ic and now it shows me under windows, battery is charging but it doesn't.
                          But it now works from charger. I will do the steps you've suggestet in the next days.
                          • atsio
                            • Oct 2013
                            • 819
                            • Greece
                            If you replaced charger (Maxim) and laptop boots. Ignore everything. I can't understand the part about the battery. What do you mean?
                            • lezsimply
                              The Wanderer
                              • 657
                              • Philippines
                              I think he meant battery tray icon in windows indicates that its charging but does not actually charge the battery itself. Probably a faulty battery?
                              • Technolix
                                • Mar 2014
                                • 15
                                yes thats what I've meant. The battery is okay, I've tested it in another laptop and there it charges. I do have a second battery which also wouldn't charge in the G62 but does in another laptop.
                                • atsio
                                  • Oct 2013
                                  • 819
                                  • Greece
                                  What is the voltage on all pins of battery connector (with battery and without battery)?
                                  What is the voltage on PR822 (with battery connected)?
                                  What is the voltage on all pins of PQ11 (with battery connected)? Check if allright, PNP FET (SI7129DN-T1-GE3).
                                  Check zener diode PD1 (B340A-13-F_3A)
                                  • Technolix
                                    • Mar 2014
                                    • 15
                                    Thanks for your help. Will check tommorow evening and will reply with results.
                                    • Technolix
                                      • Mar 2014
                                      • 15
                                      Here's the schematic diagram of my notebook.
                                      Found it. PQ811.
                                      • atsio
                                        • Oct 2013
                                        • 819
                                        • Greece
                                        Sorry, forgot to type the "8".
                                        • razenxd
                                          How can I charge that battery pack?
                                          by razenxd
                                          it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                          At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                          Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                          Now, I have noticed a few things.
                                          The "dead" battery, while connected to charger and NOT Charging will...
                                          12-05-2024, 06:11 AM
                                        • Klevjetack
                                          Charge a L19D3PDA battery externally from the laptop
                                          by Klevjetack
                                          Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                          03-05-2024, 07:26 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • gadgettree
                                          Acer Nitro AN517-52 FH51M LA-J871P Works on battery only. Won't charge.
                                          by gadgettree
                                          Hi there,
                                          I am having trouble diagnosing this gaming laptop.
                                          The laptop does not power on with AC Power only. The battery also does not charge. The laptop turns on when the battery is plugged in, regardless of whether or not the charger is plugged in until the battery dies of course.
                                          So something is stopping adapter power from getting to the laptop. I checked Adapdet to make sure that the motherboard knows when the adapter is plugged in. That works fine.
                                          I suspect the first Mosfet isn't turning on but I am unsure how to properly diagnose that...
                                          02-28-2024, 05:27 PM
                                        • bin_
                                          XPS 15 9570 will not charge but battery works
                                          by bin_
                                          XPS 15 9570 will run from battery but will not charge/run from USB-C or the DC jack. The charging light does not come on, even though it normally does when power is connected (regardless of whether or not a battery is in the machine). So it seems like something is wrong power wise. Battery is dead so it currently won't boot. Machine specs:
                                          Dell XPS 15 9570
                                          Intel Core i9-8950HK
                                          Tried 32GB DDR4 2666 and 8GB DDR4 2400 RAM
                                          Motherboard is a Compal LA-G341P
                                          I've tried removing the battery, CMOS battery, RAM, trackpad, keyboard,...
                                          12-24-2021, 03:49 PM
