MacBook pro A2251 Boot failure
  • yehuday
    • Aug 2024
    • 7
    • israel
    Hi Everyone
    I have a Macbook pro A2251 which fails to boot.
    When i try to start it the fan momentarily spins full speed, then shuts off and it doesn't start.
    This then repeats every few minutes. as if the board is stuck in a reboot loop
    When i inspected the PCB i couldn't find any indication of liquid damage
    I tried a few SMC reset sequence i found online but none helped (perhaps i did them wrong)
    i am capable of opening the case and measuring voltage at test points. i also got the brd and layout files but i have no idea how to debug this issue
    Any advice is appreciated.
    Yehuda
  • kevingill
    • Jun 2013
    • 152
    • England
    Go through the schematic and measure the main power rails voltages. Post here
    • yehuday
      • Aug 2024
      • 7
      • israel
      i couldn't really find the TP of the main power rails so i just measured a few TP with different voltage
      here is my findings so far
      PP5V_S5 - OK
      PP3V3_S3 - OK
      PP1V1_S3 - OK
      PP1V8_S5 - OK
      PP5v_main_vcore1/2/3 - OK
      PP0v9​_ssd0 - OK
      PP0V9_TBT_X_LC - No voltage
      • mon2
        • 14677
        Always post the measurements, not the interpretations of the values.
        • yehuday
          • Aug 2024
          • 7
          • israel
          This time with values
          PP5V_S5 - 5.09v
          PP3V3_S3 - 3.33v
          PP1V1_S3 - 1.09v
          PP1V8_S5 - 1.79v
          PP5v_main_vcore1/2/3 - 5.09v
          PP0v9_ssd0 - 0.89v
          PP5V_S4 - 0V
          PP0V9_TBT_X_LC - 0V​
          • mon2
            • 14677
            What is the voltage to ground of PPBUS_G3H at fuse F7000? Check both sides of the fuse. Is this voltage stable?
            Can you confirm the netname that is 0v? Is it PP5V_S4SW? The full net name from the schematics should be posted to assist in quick searches.
            Remove all power. Meter in resistance mode. Measure the resistance to ground of PP5V_S4SW. We are checking if there is a shorted part on this rail by checking the resistance to ground. One meter probe on PP5V_S4SW (anywhere on the board should be ok); other meter probe to ground (metal shield is ok).
            No power / no battery to the board during these tests.
            Usually on cases like yours, it is a good idea to test the resistance to ground of each inductor on the board. These are usually grey in color and will be with 2 leads. Each such inductor is linked to a local power rail. We are checking each power rail for possible shorted parts. So check the resistance in ohms and report any suspects. With a shorted part, the local power supply will sense this condition through the current sense leg of the power supply and power it down if out of range.
            • yehuday
              • Aug 2024
              • 7
              • israel
              thanks for the help
              netname is indeed PP5V_S4SW.
              PPBUS_G3H voltage at fuse F7000 moves between 12.1 to 12.5v on both sides. it is stable on 12.45 drops to 12.1v and then back up
              i couldn't get a resistance measurements for PP5V_S4SW​. it wasn't shortcut, it was outside the 200M range which is strange.
              all the inductors i measured (total of 9) had a resistance to ground ranging from 40 ohm to 2k ohm. none were shortfused.
              i suspect this coud be a stuck DFU issue but i can't get my hands on "apple configurator 2" dmg to test
              • mon2
                • 14677
                apple configurator 2 - is available on the Apple store. Use your apple account to access the store. There is a requirement of the OS version to permit the use of this version. If you need an older version, found that too but through another link shared by a tech on Reddit I believe. Let me know if you need the link(s).
                Be sure to use a quality USB cable.
                • yehuday
                  • Aug 2024
                  • 7
                  • israel
                  For some reason it doesn't exist on my app store only Apple configuration (not 2). Could be a country/ region thing
                  AFAIK it doesn't support macbook pro recovery
                  • mon2
                    • 14677
                    The A2251 is on the DFU list:
                    DFU Mode Restore (Macs) - LogiWiki
                    Try the download from here:
                    Download Apple Configurator 2 for Mojave : r/macsysadmin (reddit.com)
                    • yehuday
                      • Aug 2024
                      • 7
                      • israel
                      i managed to install Apple configurator 2 and attached the macbook to another macbok air but no device was detected
                      i tried all USB-c port combinations but to no avail
                      back to square 1 i guess.
                      my only hint is ATM is PP5V_S4SW​ being 0 V
                      i will try i few other power plane pins and see what comes out
                      • mon2
                        • 14677
                        Remove all power.
                        • Check current sensing resistors: R7021, R7022, R7061, R7062.
                          • Their values are all 1 ohm
                        • yehuday
                          • Aug 2024
                          • 7
                          • israel
                          okay. i see they are all located in the top side of the board.
                          Is there an easy way to access it or should i remove all flex and screws and flip the board ?
                          • PITERPENY
                            Macbook A2251 no boot
                            by PITERPENY
                            The MacBook does not boot. It is restored via DFU without errors. The MacBook charges and consumes 20V/2A. There is no sound when connecting the charger. The caps lock does not light up, but the touchpad clicks. The fans do not rotate. No signs of life. Please advise.
                            01-05-2025, 03:11 PM
                          • PITERPENY
                            macbook A2251 820-01949-A no boot no DFU
                            by PITERPENY
                            The macbook has some water damage (all cleaned) near the usb-c ports on the left side. The MacBook does not boot and is not detected in DFU! The current consumption on all ports is the same 20V and 0.079A.
                            PPBUS_G3H=12.3V
                            PPBUS_HS_CPU=12.3V
                            PPVIN_S0_PRIM1V8=12.3V
                            PPVIN_G3H_P5VG3S=12.3V
                            PPDCIN_G3H=19.99V
                            PP5V_G3S=0V
                            PP5V_S5_LDO=0V
                            PP3V3_G3H_RTC=3.38V
                            PP3V3_G3H_SSD0=3.38V
                            PP3V3_G3H_RTC_MESA=3.38V
                            PP3V3_G3H=3.31V
                            PP3V3_G3H_PMU_VDDMAIN=3.31V
                            PP3V3_G3S=0V
                            PP3V3_S0_TBT_XT_ISNS_R=3.3V
                            PPVCCIN_S0_CPU=0V
                            PP1V8_G3S=0V...
                            06-24-2024, 09:06 AM
                          • privato89
                            Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                            by privato89
                            I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                            Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                            Let's begin:
                            Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                            03-26-2024, 06:37 AM
                          • No Lan
                            [Macbook pro A1708] [Boot loop] [Trackpad ?]
                            by No Lan
                            Hey everyone,
                            Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                            Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                            Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                            05-24-2025, 03:09 PM
                          • twonk9098
                            Macbook Pro mid 2015 battery required to boot?
                            by twonk9098
                            I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                            The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                            This model has the newer trackpad which is not clickable when turned off.
                            At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                            If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                            12-10-2024, 06:51 PM
