Lenovo Legion no video after bios update nm-D563
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello
    Have this Lenovo Legion 7 16ACHg6 nm-D563 sn-PF38Y39W
    It came after botched bios udate. been in one shop and i see flashed main bios. all power phases start ok
    I flash main but still the same. SO i try to flash SIO with vertyanov programmer. reading ok, when erasing i get disconnect. after few try i get only disconnection when try to erase and when i try to read i have random read errors. is that ITE dead or i have some programmer problems?
    SIO is IT8227E-192 2116-CXA. can i replace it with ITE8227E-256 2017-BXA ?
  • questore
    • Dec 2015
    • 565
    • csongrád
    Originally posted by ktmmotocross
    Hello
    When I had the same problem, then the problem was interference with the power outlet 230v. The pc I used was plugged ín to the same power outlet As the charger of the laptop I tryed tó reprogramm. That made the readings random.
    Try using a surge protector or another outlet
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Note the difference in suffix BXA & CXA and then the size 192KB /256KB. So very likely wont work.
      On NM-D563, ITE ec will auto program if its blank.
      Try this trick. Open the EC file in hex editor and select all and autofill it with zero. This way we're creating a blank ec file of 128KB. Now flash the EC with this file. this will make your EC blank.
      99% chance your programmer will not give error when flashing blank ec file.
      Now apply power and it should auto program itself on 1st boot.
      This trick helped me on lots of ITE ec programming issues ending in errors and thus file not written correctly to EC leaving it neither properly flashed not blank.
      Good luck and update this thread whether this helped you.
      • questore
        • Dec 2015
        • 565
        • csongrád
        Good idea but be carefull, if there is interference like it was at my case, some bits Will be changed when the interference kick ín durring write process.
        • akwky
          by akwky
          Hi!
          04-14-2025, 01:56 PM
        • Thomas Dunlap
          Corrupted/Interrupted Bios Update Lenovo Legion S7 15ACH6
          by Thomas Dunlap
          I have a Lenovo Legion S7 15ACH6 that was interrupted during a BIOS update and is now bricked. Symptoms: fans spin, RGB keyboard lights up, but no display/POST.
          The BIOS chip is a Gigadevice GD25LR128. I’m using a CH341A with a 1.8 V adapter. In AsProgrammer I selected GD25Q128 (since GD25LR128 isn’t listed) and successfully made a dump (BiosDump2_pf3eg12j.rar).
          My understanding is that I’ll need a known good BIOS dump for this exact model, ideally matched to my laptop’s serial number (PF3EG12J), and that the Windows license key/serial should also...
          09-26-2025, 12:45 PM
          LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
          This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
          09-12-2024, 02:30 PM
        • to5it0
          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
          by to5it0
          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
          I have opened the laptop and identified the main BIOS chip...
          10-24-2025, 01:35 AM
        • mkdj
          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
          by mkdj
          Dear all,
          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
          Here the steps I have taken to fix the laptop:
          - downloaded latest BIOS from Lenovo Website...
          10-18-2025, 03:43 AM
