Dell G15 ryzen edition black screen 2 amber 1 white
  • hcinne
    • Jul 2024
    • 9
    • Algeria
    I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the power button for 1minute and reconnected the battery but it didn't work so i grabbed the multimeter and checked the main power rail and the 19V is present (no short to ground) the 5V rail and the 3V rails are present too then i went into resistance mode i measured all the cpu vrm coils to ground, 4 coils read 5ohms the other one read 9ohm which i believe is right? now for the gpu vrm coils all 4 coils measure 0.4ohm to ground (0.2ohm the resistance of the probes) the gpu is GN-20-P0-A1 which i believe is too low but i'm not sure,
    the main bios voltage (winbond 25Q16JWSIQ) is missing on pin8 and from all other pins, the ec bios voltage (winbond 74M12JWSIQ) on pin8 is 0.352V.
    When i power it on i get voltages on the cpu and it gets warm too but not on the gpu.
    It's kinda confusing because according to the battery indicator code it's a cpu failure but i get no voltage on the main bios and a very low reading on the gpu vrm coils so what is causing the problem cpu, gpu or could it be a corrupt bios?
    motherboard is LA-K454P Rev: 1.0(A00)
  • piernov
    • Jan 2016
    • 4435
    • France
    https://www.badcaps.net/forum/troubl...ines#post79043
    When requesting help, please attach a picture of the board with resistance to ground measurements (no AC adapter/battery) and voltage measurements after triggering power button (with AC adapter) on all the large inductors .
    https://www.badcaps.net/forum/troubl...61#post1459061
    GPU VCore with newer NVidia GPU can even measure less than 1 ohm. It's normal.
    • hcinne
      • Jul 2024
      • 9
      • Algeria
      Here are the pictures with resistance to ground readings and voltage after power on for all the coils it might interest anyone with same board looking for these readings
Name:	LA-K454P Rev 1.0 (A00) Face A.jpg
ID:	3315450 Click image for larger version
Name:	LA-K454P Rev 1.0 (A00) Face B.jpg
      piernov
      "GPU VCore with newer NVidia GPU can even measure less than 1 ohm. It's normal"
      yes i had my doubt about the gpu reading so at least the gpu might not be the issue
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        25Q16=2MB so it cant be the main bios. Main bios should be atleast 8MB or may be 16MB.
        GPU resistance to GND seems fine but the issue at hand is GPU is not powered at all.
        • hcinne
          • Jul 2024
          • 9
          • Algeria
          yes indeed i was mistaken the main bios is winbond 74M12JWSIQ after reading some topics related to it, it is identified as W25Q128FW [1.8V] so my main concern is that when powering on the laptop i should get 1.8v on pin8 of the bios also maybe for the gpu to get voltage the bios must post first?
          So before desoldering the bios chip and program it should i check something else?
          • hcinne
            • Jul 2024
            • 9
            • Algeria
            I modified the original bios 1.20.0 that i extraced from the dell website and flashed it now its working again
            • valieromarco
              Marco
              • Aug 2014
              • 26
              • italy
              Hello
              I got same your issue can you attach the working bios?
                • 20848
                Originally posted by valieromarco
                Hello
                Laptop bios requests go here -> https://www.badcaps.net/forum/troubl...-requests-only
                Please read the rules before posting, you must post the laptop serial number - SNID or Service tag, post in an existing topic if there is one, post your backup etc,etc -> https://www.badcaps.net/forum/troubl...before-posting
                Also, make use of the forum search engine, what you are looking for might already be posted !​
                • 3pka
                  • Aug 2024
                  • 18
                  • Mongolia
                  what mod are you done? I have same issue for Dell Inspiron 15 3515 Ryzen. Measure all seems ok and condition exactly same. It was 1 white 3 amber before. Then i checked BIOS but image was broken. Then i flashed factory bios but indicator changed to 1 white 2 amber.
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • benek123
                    RedmiBook 15 pro 2023 Ryzen - after replace LCD screen work only in windows
                    by benek123
                    I replaced the screen and LCD ribbon in Redmi Book 15 Pro Ryzen 2023. After replacing, the image on the screen is only visible in Windows 11 - when the AMD drivers are loaded.
                    The screen is backlit but there is no image in: bios, post, when loading windows, in linux (ubuntu boot from usb), windows 10 PE.
                    When I disconnect the EDP connector from the board and connect the HDMI cable, the image is visible everywhere good, in the BIOS you can see 2/3 of the image, i.e. 1920 pixels out of 3000 pixels.
                    I checked the EDID with the old screen - it is identical.
                    What...
                    09-24-2024, 03:28 PM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • smic717394
                    by smic717394
                    07-25-2024, 10:16 AM
                  • Raven7032
                    Dell G15 Ryzen Edition (LA-K454P) – No SPI Activity, No Boot, No startup
                    by Raven7032
                    Hello everyone!
                    Stucked with this problem.
                    Model: Dell G15 Ryzen Edition
                    Board: GDL LA-K454P
                    Symptoms:
                    • Board powers on (consumption ~0.5A), but no boot or display.
                    • Fans spin briefly, keyboard backlight turns on, then fans stop.
                    • Can be shut down via power button (EC active).
                    • No POST, no BIOS splash, no backlight.
                    • Led is blinking 2 orange 1 white
                    • No activity on SPI bus (no CS#, no CLK, no MOSI/MISO) even after pressing power.
                    • No APU_PCIE_RST# - 0V
                    Measurements:
                    • All voltage rails present: +1.8V, +0.75V, +3VS, +5VS, VDDCR_VDD, VDDCR_SOC, DDR VDDQ, VTT.
                    • EC_RSMRST#
                    06-26-2025, 11:47 PM
