Hp omen charge only when power off
  • mouhmmc
    πŸ™‚β€‹
    • Sep 2016
    • 36
    • india
    Hi
    Has anyone ever had a situation like this? The computer only charges when it is turned off
  • mon2
    • Dec 2019
    • 14663
    Be sure the power adapter is correct for this laptop with enough power (watts).
    • mouhmmc
      πŸ™‚β€‹
      • Sep 2016
      • 36
      • india
      Yes correct
      • mouhmmc
        πŸ™‚β€‹
        • Sep 2016
        • 36
        • india
        Is there a solution please?
        • mon2
          • Dec 2019
          • 14663
          Check the center needle like pin of the power adapter. It cannot be bent. This pin outputs a detection voltage to announce the adapter’s power rating.
          https://www.quora.com/My-HP-laptop-o...t-might-be-the
          • ipatch
            troubleshooting microsoft surface pro 4 no power no led charge light
            by ipatch
            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
            10-05-2023, 11:59 AM
          • proxneo
            iPad A2197 no power, A10 and other IC become warm, only 0.5A charge
            by proxneo
            Dear reader
            TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
            I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component...
            12-01-2023, 04:14 AM
          • PantherDave
            by PantherDave
            Hi all!
            I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
