Help identifying chip ProBook 650 G5
  • Kwisatz Haderach
    • Aug 2015
    • 15
    • Spain
    Can someone help me identify this chip?
    U3003 board 6050A3028501 - MB - A01 (scheme not available) ProBook 650 G5
    Marking code j7 0b0?
    Package DFN6 1x1.5mm
    Pin 2 : GND
    Pin 5: 3,3V
    Near LVDS conector.
    Thanks in advance.
  • mon2
    • Dec 2019
    • 14660
    Could be this one (used on similar boards from HP):
    Part # 74LVC1G3157FZ4 (can be replaced with NXP = Nexperia 74LVC1G3157GM
    74LVC1G3157 (diodes.com)
    • Kwisatz Haderach
      • Aug 2015
      • 15
      • Spain
      Thanks for the information🙏
      It's an analog switch! 🤦‍♂️
      My board has the missing component and there is no image on the panel
      I'm going to try short 1->4 or 3->4
      At the moment I have not found any donor board in my scrapyard​
      • Kwisatz Haderach
        • Aug 2015
        • 15
        • Spain
        Finally I connected pin 1 to 4 and the laptop is working. Thank you very much mon2
        • mon2
          • Dec 2019
          • 14660
          Awesome A bit of good news to start the day here.
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • Loki_Fido
            Requesting help identifying chip in Macbook Pro A2485
            by Loki_Fido
            Hi ya folks,
            I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
            It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
            I replaced it and the SSD are fine. No more shorts.
            But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
            But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
            Chip marking...
            08-07-2025, 10:17 PM
          • skdsp
            Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
            by skdsp
            I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
            Attached is the photo.
            Thank you!
            09-27-2025, 09:05 PM
            by SMDFlea
            Bad...
            09-02-2021, 04:40 PM
