dell latitude e6420 charger with 19v 3,3a
This topic has been answered.
  • acata
    • Jun 2021
    • 53
    • Indonesia
    I'm working on dell latitude e6420. Default power input is 19,5v 3,34a. But unfortunately, it's not turning on whenever i charge with the default power input. Instead it's turning on when i switch it to 19v 3,3a.
    What do i missed? Is there any faulty on the machine so it's can to be turned on with the default power input.
  • Answer selected by acata at 07-17-2024, 05:45 AM.
    acata
    • Jun 2021
    • 53
    • Indonesia
    I found a donor and replaced the ic cd3301. And i need to jumper pin 12 to PC274 and it worked.
    Pin1 19.65 (psu)
    Pin9 3.3v
    Pin18 3.3v
    Problem solved.
    • mon2
      • Dec 2019
      • 14659
      Locate the charger IC - which is onboard? Check the voltage of ACDET pin.
      • acata
        • Jun 2021
        • 53
        • Indonesia
        I'm sorry. On 19v or 19,5v input?
        • acata
          • Jun 2021
          • 53
          • Indonesia
          I just found that the ic selector is burnout. its PU14, CD3301. Is there a way to bypass this? or just replace it with the new IC?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            https://www.youtube.com/watch?v=IQb_tOlPCaA
            • acata
              • Jun 2021
              • 53
              • Indonesia
              Pin1 19.65 (psu)
              Pin9 3.3v
              Pin18 3.3v
              Problem solved.
              • acata
                • Jun 2021
                • 53
                • Indonesia
                And thank you for your assistance
