HP Laptop 25-dw2000nl Power supply
  • RGSound
    • May 2024
    • 12
    • Italy
    Good morning,
    I have a problem with my HP 25-dw2000nl laptop. Since a couple of days the battery is not charging. I've tried changing both the power supply and the battery but either way it won't charge or hold a charge.
    The laptop then only turns on and works when connected to the power supply. As soon as I unplug it it has no charge and shuts down. What could be the problem, can you help me?
    I'm sorry if the topic is not in the right area.
  • mon2
    • Dec 2019
    • 14321
    Hi. Are the replacement power adapter and battery known good parts and suitable for this model of laptop?
    Do you have a multimeter? Soldering tools? Which logic board is onboard? Share pics of all silkscreen text of the logic board.
    • RGSound
      • May 2024
      • 12
      • Italy
      Thank you for the answer. Yes they are both suitable for this model. I have all the tools I attach some photos if there is need for something more specific let me know.
      • mon2
        • Dec 2019
        • 14321
        Would you see any white silk screened text on the board for identification? Perhaps 'LA-****' or 'NM-****' or similar. This will assist us on perhaps finding a schematic. If not, need you to trace where the power enters the board and which mosfets are near the charging port and finally the charging IC that is driving these mosfets. Not impossible to work without a schematic but it helps.
        • RGSound
          • May 2024
          • 12
          • Italy
          I found it, I leave photo attached. LA-H328P
          • mon2
            • Dec 2019
            • 14321
            Great. Could not find this exact board but maybe found a similar logic board from HP.
            Can you confirm the topside chip markings for PUB1 = charging IC on the board?
            Click image for larger version  Name:	pub1_schematic.png Views:	0 Size:	212.8 KB ID:	3309593
            Click image for larger version  Name:	pub1.png Views:	0 Size:	71.3 KB ID:	3309592
            • RGSound
              • May 2024
              • 12
              • Italy
              Is this one?
              • mon2
                • Dec 2019
                • 14321
                Perfect! Yes, this is the charger IC and will be very helpful to diagnose.
                It is this charger IC that is detecting your power adapter and then creating a boosted voltage to enable the DCin mosfets to power the board. It is a critical part on the board.
                You can download the datasheet for this part from here:
                bq24735 1- to 4-Cell Li+ Battery SMBus Charge Controller for Supporting Turbo Boost Mode With N-Channel Power MOSFET Selector datasheet (Rev. B)
                Use the datasheet to review the topside view and where the pin #1 is located on the chip. Pin #1 = circle on the top left of the IC -> then you will count in a COUNTER-CLOCKWISE direction (as shown in the datasheet top view).
                Remove all power. No battery. Meter in resistance mode.
                Measure the resistance (not diode mode) to ground of pin # 1 and then of pin # 2. Post each measurement. We are checking if the main power rail is shorted and causing the charger IC to power OFF to prevent damage.
                • mon2
                  • Dec 2019
                  • 14321
                  My bad - unit works but does not charge. Are your meter probes sharp at the tips? We will need to check some points on the board while it is powered on.
                  Interested in the voltage to ground of pin # 5 - it is a corner pin. Red probe on pin #5 and black probe to ground (shield is ok). What is the voltage measurement?
                  • RGSound
                    • May 2024
                    • 12
                    • Italy
                    I will try to do this test, even I am not very experienced. As for the shield, what do you mean?
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                    • shamsudeen
                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                      by shamsudeen
                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                      07-19-2025, 07:14 AM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                      Recap an Adjustable Power Supply DC 0-48 / 0 to 10 A going to use it to charge battery packs
                      by sam_sam_sam
                      I have a 24 volt version of the same type of switching power supply but that one I am relocating to meter module and I might do the same thing with this one but I have to modify an enclosure that is not made for this type of switching power supply in fact I am not sure exactly what type of switching power supply it actually fits because none of one's that I have the screws holes do not line up and not even close but the switching power supply fits in the enclosure
                      So I have take out the switching power supply board out of its enclosure and drill the hole so that it can be mounted...
                      04-14-2024, 05:45 PM
