Super IO Chip ENE KB9542qe
  • MasEkapses
    • May 2024
    Hello everybody, i am diagnosing a hp omen 15-dh0007ng motherboard with no power. After a bit messuring I found out that the 3v rail is missing. Looking after that I found a short on a cap on an step down regulator ic. After removing the cap the short was still there. I also removed the ic looking if maybe this is internally shorted. The short remained still there. After that I tried to inject voltage 3.0v on the 3v rail and I found through thermal camera the super iO chip heating up. It had a current draw of about 0.7A. Now I want to replace the super iO chip but I found out that they contain bios programming and I would have to reprogram the new one. Can somebody with more experience clear this up to me? I have schematics of the MB as boardview files if this is needed. Also please forgive my English it's not my native language.
  • Victor Moreira Silva
    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
    by Victor Moreira Silva
    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
    Well, my decice specs are the following:
    Model: Acer Nitro 5 AN517-54-55T5
    CPU: Intel Core i5-11400H
    GPU: NVIDIA GeForce GTX 1650
    Motherboard: GH51G LA-L181P Rev:1c
    The symptom:
    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
    05-26-2025, 10:49 AM
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    Yesterday, 12:20 PM
  • ongobongo
    Asus ROG Ally - Super IO Chip replacement
    by ongobongo
    anyone here who has experience with replacing the super IO chip of an ROG ally?
    I have one on my bench which has a burnt super io (ITE 5125VG-192). On some devices the super-io downloads it's firmware from BIOS if it's empty. As i don't have a programmer for this chips i hope someone here has already changed the chip and can give me a hint if it's working with an empty chip if it needs external programming.
    Ongo
    11-17-2024, 11:27 AM
  • fab13
    Nintendo Switch lite charging chip heats up and does not short circuit
    by fab13
    Hello everyone
    Small technical problem on a Nintendo Switch lite
    Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
    After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
    When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
    Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
    09-16-2023, 04:59 AM
