2012 Mac SSD (SanDisc Wide One) burnt chip identification
  • abajor
    • 178
    I have an SSD from a 2012 to early 2013 Macbook pro, the SanDisk model SD5SL2-512G-120SE
    Attached is a photo of the burnt chip. I'm assuming it's some sort of voltage regulation chip. The numbers are obscured by the damage.
    I am attempting to recover data from this SSD, obviously this chip needs to be replaced before anything can be done.
    Is there anything else I should check to verify the health of the NAND?
    Thanks if anybody knows what part I'm looking for.
  • abajor
    • 178
    I found a non blown up drive.
    With a clear view of the chip number.
    I'll try to figure out what it is.
    If any y'all are familiar with this device I would be very appreciative.
    • mon2
      • Dec 2019
      • 14677
      How many contacts do you see?
      Review this datasheet:
      https://www.mouser.com/datasheet/2/3..._D-2318934.pdf
      • abajor
        • 178
        It looks like 5 but its hard to tell with the underfill
        Oops I mean 6 pins
        • abajor
          • 178
          In my search I kept coming up with a Schmidt Trigger but they all had 3 pins on the one side instead of 4.
          • abajor
            • 178
            It is indeed 8 pads, interesting can hardly see the other two through the under fill.
            hopefully no other shorts.
            • abajor
              • 178
              mon2 Thanks by the way. Luckily the only thing that fried was the CMOS chip so it was a simple replacement to recover the data.
              • mon2
                • Dec 2019
                • 14677
                Great! Which part did you use for the replacement?
                • abajor
                  • 178
                  https://www.digikey.com/en/products/...102PT1G/921573
                  Same one you pointed out.
