lenovo nm-c362 no power
  • madjid911
    • Dec 2016
    • 390
    • France
    Hello, I have a Lenovo FG541 FG741 nm-c362 REV 1 (ideapad l340-15lrh gaming model? I no longer have the label), the laptop does not start at all, I noticed that the controlled micro controler was in short circuit, I ordered one for this pre-programmed model, it is very well welded.
    I now find the 3V3, I also have the 5V, but no indicator, no reaction from the laptop, so I reprogrammed the bios via this link https://www.badcaps.net/forum/troubl...-c362-help-plz
    but still no reaction
    I have 3V3 on the eeprom bios as soon as I plug in the original charger, the battery is indeed 3V, on the other hand it does not charge the battery, I remain at 0V1, so I changed the bq24708S in case it was defective, I had it in stock, but still no reaction.
    I don't know where to look anymore, I no longer have any shorts and the voltages seem good from the battery charge, can you help me? THANKS
  • madjid911
    • Dec 2016
    • 390
    • France
    maybe the ITE IT8586E is not reprogrammed well? bios EC is in bios eeprom chip or it is in ITE IT8586E for this model?
    • mon2
      • Dec 2019
      • 14139
      bq24708S
      Share the following voltages from the charger IC:
      VCC
      REGN
      ACOK
      ACDRV
      ACN/ACP
      • madjid911
        • Dec 2016
        • 390
        • France
        VCC
        REGN
        ACOK
        ACDRV
        ACN/ACP
        APDIN 20V60
        ADAPTER_ID 1V8
        VCC 20V35
        REGN PIN24 6V07
        ACOK PIN5 3V3
        ACDRV 20V57
        ACN 20V60
        ACP 20V60
        • mon2
          • Dec 2019
          • 14139
          ACDRV is not boosted to ~25v.
          Carefully flux and remove PR310 resistor. Do not lose this part.
          Then power up again and check the voltage to ground of ACDRV. Now do you see ~25v on this pin?
          • madjid911
            • Dec 2016
            • 390
            • France
            I'm sorry I measured this pin wrong, the ACDRV is at 26V47
            • mon2
              • Dec 2019
              • 14139
              Then ok. Measure the voltage to ground of each inductor on the board. Each inductor is linked to a local power supply. Confirm the power rail(s) are present for each stage.
              • madjid911
                • Dec 2016
                • 390
                • France
                PL3501 3V3
                PL3502 5V
                PL3502 0V2
                PL503 0V => I notice a short on PL503 pin 2, I don't see any capacitors in poor condition, I will try to inject voltage to see where it heats up, unless the 32 ohm resistor is normal ?
                Click image for larger version  Name:	PL503.png Views:	0 Size:	135.9 KB ID:	3305991
                PL501 0V
                PL7502 0V
                PL3201 0V
                • mon2
                  • Dec 2019
                  • 14139
                  Wait - 32 ohms is fine since this is a low voltage rail. This is normal.
                  • madjid911
                    • Dec 2016
                    • 390
                    • France
                    ok thanks for the infomation, I didn't inject any voltage, I don't see any other problem
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Check EC_RST,RSMRST#,LIDSW#
                      • madjid911
                        • Dec 2016
                        • 390
                        • France
                        EC_RTCRST#_ON 0V
                        EC_RSMRST# 0V
                        LID_SW# 3V28
                        CLK_PCI_EC 1V29
                        • mon2
                          • Dec 2019
                          • 14139
                          EC_RTCRST#_ON 0V
                          EC_RSMRST# 0V
                          These signals means that the EC is parked in RESET mode.​
                          • madjid911
                            • Dec 2016
                            • 390
                            • France
                            do I have to reprogram it? it is very well welded
                            • mon2
                              • Dec 2019
                              • 14139
                              Not sure but confirm if the EC is being powered @ +3VL_EC. You can check on any of the nearby caps or RE1 / RE3 resistor pads. The resistors are bypassed with PCB traces so should be easier to probe with the meter.
                              • madjid911
                                • Dec 2016
                                • 390
                                • France
                                +3VL_EC is good 3V
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  What about EC_RST? I didnt asked for EC_RTCRST. They are different.
                                  • madjid911
                                    • Dec 2016
                                    • 390
                                    • France
                                    Because I can't find anywhere EC_RST, there is EC_RTC_RST# 3V13
                                    • madjid911
                                      • Dec 2016
                                      • 390
                                      • France
                                      I haven't found how to repair it, maybe the micro controller arrived defective, I bought it on Ali Express
                                      • madjid911
                                        • Dec 2016
                                        • 390
                                        • France
                                        do you know if I can reprogram the sio chip with my xgecut56 programmer, I also have the CH341A for PS5 uart, and also the lattice hw-usbn-2a ?
                                        I have never reprogrammed sio controler
                                          Lenovo 3000 Series Schematic
                                          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                          3000 C100 laptop with Braille keyboard
                                          Lenovo 3000 C
                                          C100, C200 - 15-inch XGA screen
                                          Lenovo 3000 N
                                          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                          N500 - 15.4 inch screen.
                                          Lenovo 3000 V
                                          V100, V200 - 12.1-inch WXGA models
                                          Lenovo 3000 G
                                          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                          10-04-2024, 06:05 AM
                                          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                          09-06-2024, 06:40 AM
                                          This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                          09-06-2024, 06:06 AM
                                        • tommy97
                                          Lenovo L340-15IRH fg541/fg741 nm-c362 rev 1.0 No power
                                          by tommy97
                                          i've got for repair Lenovo L340-15IRH fg541/fg741 nm-c362 rev 1.0, laptop have instant short 20v 0.20amp draw, lv5083a goes to 100degree, i've removed 1 shorted cap next to the IC and short still remain, from look of it short comes from legs 16-25, i can't find what this IC i believe is 3/5V regulator?
                                          First mosfets normal 20v Source and drain and Gate 25v...
                                          04-30-2024, 11:43 AM
                                        • derradji89
                                          Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                          by derradji89
                                          Hi everyone 🤗
                                          I have a Lenovo MIX 320-10lCR computer.**
                                          1. **Operating System**: Windows 10 ** Education** 64-bit.
                                          2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                          3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                          4. **BIOS Chip Reflashing**: Currently,...
                                          04-19-2025, 03:04 PM
