aspir a515 BQ24780 voltage missing
  • nassih
    • Oct 2015
    • 276
    • morocco
    hello i have an acer aspire a515 turns on without battery when i put battery it turns off,
    voltages on bq24780:
    acn: 18.24v
    acp: 18.24v
    CMSRC:18.74v
    ACDRV:18.73v
    ACOK: 0v
    ACDET: 0v
    VCC: 19.16v
    REGN: 0v
    tanks
  • mon2
    • Dec 2019
    • 14518
    ACDET: 0v
    This is the wrong value to detect the power adapter. Something is wrong here.
    Also,
    acn: 18.24v
    acp: 18.24v
    This voltage should not be present since the ACDRV is not high enough to enable the 2 x DCin mosfets. Remove the battery and check these measurements again. Do you still see this voltage? If yes, then double check the DCin mosfets - one of them is defective - check the 2nd one first.
    Only if the ACDRV voltage is ~25 volts should BOTH of the DCin mosfets enable to supply the ACN/ACP voltages. Otherwise, ACN/ACP should be the battery voltage.
    The charger IC will enable the ACDRV boosted voltage only after ACDET is > 2v4 AND the REGN voltage is ~6 volts. You do not have REGN at the proper voltage. This is fundamental should be immediately available.
    The charger IC could be defective but start with the above checks. Time for lawn care for me...
    PS: Watching Vagabond (Korean) show on Netflix - they filmed a lot in Morocco - looks very nice Years ago, met Tom Sizemore at the Detroit Airport and shot the breeze with him. He mentioned how he was going to film Black Hawk Down in Morocco (Ridley Scott film?) - nice chat with him for a few minutes. He had relatives in Michigan and was here for Christmas holidays.
    • nassih
      • Oct 2015
      • 276
      • morocco
      tanks mon2, and I hope everything is going well for you
      so the voltages I gave are without battery, and I changed the charger ic with another one that works on another board, same result​
      • mon2
        • Dec 2019
        • 14518
        Which model is yours? Check the logic board markings.
        • nassih
          • Oct 2015
          • 276
          • morocco
          A515-54G-75LV
          motherboard : da0zawmb8g0 rev g
          • mon2
            • Dec 2019
            • 14518
            See attached. Review the ACDET resistors. They must be able to supply a voltage that is > 2v4. The raw adapter voltage on its own is too high and will kill the charger IC so 2 resistors are used as a voltage divider to lower the threshold voltage to a safe value.
            Most likely the high side resistor is defective or the trace is not making it to the power adapter. So check resistor @ PR31.
            • nassih
              • Oct 2015
              • 276
              • morocco
              PR31: 880k
              PR211: 136k
              • nassih
                • Oct 2015
                • 276
                • morocco
                this schematic is for the same board?
                • mon2
                  • Dec 2019
                  • 14518
                  In my database, yes, this is the schematic. The resistor values are ok. Carefully measure the voltage on each side of the resistor @ PR31. One side must be the adapter voltage of ~19 volts.
                  Share the voltage to ground measurements on PR31.
                  If no voltage, remove all power -> meter in DIODE mode. Short your meter probes and the meter should tone beep. Then place one probe on the PR31 resistor; other meter probe @ PQ1 (first DCin mosfet) - pin 1-2-3 (any one of these is ok). You should hear a tone beep.
                  If no tone beep, touch the other side of the PR31 resistor. One of the sides of PR31 must tone beep. If not, then there is a PCB trace break between PR31 and the main adapter voltage.
                  Note: For this repair, be 100% sure that you only mate the adapter voltage to the proper side of PR31. DO NOT send this high adapter voltage directly to the charger IC.
                  Share a good pic of the PR31 & PR211 area of the logic board for a quick review. It is important that PR31 high side only mates with the power adapter. The common connection between PR31 & PR211 = ~2v4 when all is working.
                  • nassih
                    • Oct 2015
                    • 276
                    • morocco
                    voltage on pr31 is 19.27v coming from adapter, the other side is 0v
                    I can confirm that all connections are correct and checked.​
                    • mon2
                      • Dec 2019
                      • 14518
                      Good. Check the resistance to ground of ACDET. No power during this check. PR31 may be defective but ACDET may be shorted.
                      • nassih
                        • Oct 2015
                        • 276
                        • morocco
                        ACDET: 124k resistance to ground
                        • mon2
                          • Dec 2019
                          • 14518
                          Remove PQ17 and test again. On your logic board, the DCin power connector (PJ2) is defective.
                          When properly mated with the power adapter, the ADP_ID pin should go low and this action will cause the mosfet @ PQ17 to turn OFF. Only when the mosfet @ PQ17 is OFF, will the proper voltage appear at the ACDET pin on the charger IC.
                          Instead, ADP_ID pin is floating and this action causes the resistors @ PR235 & PR230 to build a voltage divider. The voltage presented at pin 2 (GATE) of the mosfet @ PQ17 is high enough for the mosfet to turn ON.
                          When PQ17 is turned ON, the ACDET pin will shorted to ground and this is why you are observing a 0 volts measurement on the ACDET pin. Then the charger IC believes there is no power adapter connected.
                          Click image for larger version  Name:	adp_ID_pin.png Views:	0 Size:	48.1 KB ID:	3304621
                          Click image for larger version  Name:	ADP_ID.png Views:	0 Size:	43.5 KB ID:	3304616
                          • reformatt
                            • Feb 2020
                            • 1444
                            DC jack should click when the adaptor is inserted, shorting ADP_ID to ground. You will also hear an audio bleep if that connection is being made. You can manually just short that pin to ground to prove it. The intent is disable the adaptor till it's fully inserted into the jack.
                            First things I check for on any Acer is power button on the keyboard and DC jack. They are stock faults.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Are you sure REGN is at 0 Volts as per your post#1?
                              • nassih
                                • Oct 2015
                                • 276
                                • morocco
                                hi mon2 sorry yesterday I couldn't finish the work we started, indeed you were right the transistor PQ17 receives a voltage of 9v on its gate and this short circuit with the ground and ACDET, so I removed the transistor and there I have 2.6v on ACDET, but still ACDRV low (18.75v) and ACOK 0v​
                                • mon2
                                  • Dec 2019
                                  • 14518
                                  Good start. Confirm the details by mcplslg123 from post # 15. Now that ACDET is OK; chip is being powered; REGN must be ~6 volts. Since it is not, the ACDRV voltage is not boosted.
                                  Is this pin soldered in ok?
                                  Remove all power -> meter in resistance mode -> measure the resistance to ground of the REGN pin. If there is an excessive load, this LDO voltage rail will not work. This is a low current power rail and should always be on at 6 volts.
                                  Has this charger IC been replaced? If not, it may be defective and needs to be replaced.
                                  • nassih
                                    • Oct 2015
                                    • 276
                                    • morocco
                                    yes tanks mcplslg123
                                    REGN is 0v,the ic charger still good its working on another board and soldered correctly
                                    resistance to ground of the REGN pin is 50k
                                    • mon2
                                      • Dec 2019
                                      • 14518
                                      Confirm the capacitor PC118 is present on the board and soldered to this same REGN pin. It is important to support the 6 volt output.
                                      Consider to flux and carefully remove the gate resistor that is on the ACDRV pin at PR105. Do not lose this 4k ohm resistor.
                                      Then power up again and check if REGN (6 volts) and ACDRV (~25 volts) are at their proper voltage. Be sure that the charger IC is well soldered on the board.
                                      • nassih
                                        • Oct 2015
                                        • 276
                                        • morocco
                                        I checked VCC pin (PQ24780) it is not present 0v, so I was going to check its path it comes from the power resistor PR16 which cracked(i dont now how, after change it I have now all the voltage on the IC charger
                                        tanks mon2 ,mcplslg123​ and all the community
                                        • Kshi
                                          acer a515-52g-4830 5valw 3valw missing
                                          by Kshi
                                          hello,
                                          this is my third time trying to revive dead laptops.
                                          I got this acer does not have power light
                                          First I test
                                          dc 19v-ok but +5valw and +3valw is missing
                                          i remove the board to test more but i didnt find anything
                                          no shorts no corrosion
                                          but i get +3vlp and +5vlp present
                                          and now i dont know what to do anymore
                                          hope someone can help me and improve my skill
                                          Link to schematic - https://www.badcaps.net/forum/troubl...nd-mobile-devi...
                                          07-24-2025, 12:22 PM
                                          Acer Aspire A515-57-5920 Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire A515-57-5920 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-57-5920 boardview and A515-57-5920 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 07:20 AM
                                          Acer Aspire A515-57-73QJ Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire A515-57-73QJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-57-73QJ boardview and A515-57-73QJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          Acer Aspire A515-58M-57GP Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire A515-58M-57GP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-58M-57GP boardview and A515-58M-57GP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 07:19 AM
                                          Acer Aspire A515-48M-R4UK Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire A515-48M-R4UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-48M-R4UK boardview and A515-48M-R4UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
