A1502 2015 820-4924 no power
  • iMuhtaseb
    • Jan 2017
    • 122
    • Palesine
    board came in cleaned up from a previous technician.. after examining the board visually I've seen some work done on the EFI/firmware..
    I've taken the chip out and it reads ok on Mac EFI Toolkit, I can read the SN and other information normally..
    I have taken a look into the board and I could not find anything suspecting.. I tried to look for corroded chips or corroded caps even to see if there's any areas damaged by liquid and I could not..
    I've taken some measurements:
    PPBUS 12.6
    PP5V_S5 present
    PP3v3_S5 present
    S4 rails when the problems happen..
    PM SLP S4 L not present (0.200mv).. although it powers on when I plug in the MagSafe power adapter and it shuts down after 2 attempts.. (S0 rails do that as well as I mention down below)
    PP5V_S4 not present (no shorts)
    PP3v3_S4 not present (no shorts)
    The only rail I've seen a low diode mode readings compared to flexBV is PP3V3_S3RS0_CAMERA and I cannot precisely know if this is the real cause of not..
    Measuring further
    PP5v_S0 is present when I plug the MagSafe power adapter and it shuts itself down to 0.400mv.. no shorts and diode mode good
    PP3v3_S0 is present (shouldn't be off since S4 is not present? this is weird no?)
    bench PSU shows a 0.120 to 0.320 milli amps consumption when I plug the MagSafe power adapter then it stays 0.02 without consumption afterwards..
    this is a tough and I cannot pinpoint exactly which signal or line is missing
  • mon2
    • Dec 2019
    • 14050
    PM_SLP_S4_L is an active low signal. If this signal is at 0 volts, this signal is true.
    Remove all power. Meter in resistance mode. Measure the resistance to ground of each inductor.
    Test with a known good bios since it was messed with by the last technician.
    • mon2
      • Dec 2019
      • 14050
      If required, have access to a number of bios images for this model. Let me know.
      • reformatt
        • Feb 2020
        • 1403
        Do you get Vcore during the initial power on? Double pulse is usually bad cpu in my experience on this vintage of boards.
        • iMuhtaseb
          • Jan 2017
          • 122
          • Palesine
          I've rewritten new bios with clean me and its still exhibiting the same behavior..
          I've measured inductors with resistance mode and couldn't find shorts or low resistance readings..
          • iMuhtaseb
            • Jan 2017
            • 122
            • Palesine
            hm.. yes I do.. I have the Vcore and it drops after the second pulse..
            • mon2
              • Dec 2019
              • 14050
              Remove all power. Meter in DIODE mode.
              Measure the dual common cathode diode @ D7005.
              Red meter probe on pin # 1 of D7005; black meter probe on pin # 2 of D7005. The diode should conduct. Reverse the meter leads and the diode should block.
              Repeat the tests with pins # 3 & pin # 2.
              Post all measurements.
              Click image for larger version  Name:	D7005.png Views:	0 Size:	72.0 KB ID:	3299189
              • iMuhtaseb
                • Jan 2017
                • 122
                • Palesine
                Pin 1 with RED pin 2 with black: 2.328
                Pin 1 with BLACK pin 2 with red: OL
                Pin 3 with RED pin 2 with black: 2.460
                Pin 3 with BLACK pin 2 with red: 0.227
                Pin 3 with RED pin 1 with black: OL
                Pin 3 with BLACK pin 1 with red: 0.226​
                • mon2
                  • Dec 2019
                  • 14050
                  Replace this part and test again.
                  Pin 3 with BLACK pin 2 with red: 0.227​
                  confirms this part is defective.
                  • iMuhtaseb
                    • Jan 2017
                    • 122
                    • Palesine
                    I have replaced the diode and board is still exhibiting the same behavior.. I have compared the measurements I have taken from another board and it reads the same.. the diode readings was and still OK I suppose.
                    • iMuhtaseb
                      • Jan 2017
                      • 122
                      • Palesine
                      Looking into the board using a thermal camera and putting it on power I can see the CPU starts to heat up a little then shuts down.. as well as the camera IC but I guess its associated with the PCH that's why it heats up..
                      A teeny little warmth is coming from the SMC as well..
                      • mon2
                        • Dec 2019
                        • 14050
                        With no power to the board, measure the resistance to ground of each pin of this dual diode.
                        So measure pin #1 to ground; #2 to ground; #3 to ground. Post each measurement.
                        • iMuhtaseb
                          • Jan 2017
                          • 122
                          • Palesine
                          Pin #1 resistance to ground 72 kilo ohms.
                          Pin #2 45kilo ohms
                          Pin #3 490 kilo ohms
                          • mon2
                            • Dec 2019
                            • 14050
                            Check the resistance to ground of the CPU power rails. If too low, the CPU may be defective. The diode measurements are ok.
                            • iMuhtaseb
                              • Jan 2017
                              • 122
                              • Palesine
                              L7320 9.9 ohms
                              L7310 9.8 ohms
                              L7630 246 ohms
                              L1270 244 ohms
                              L1290 507 ohms
                              L1275 240 ohm
                              • mon2
                                • Dec 2019
                                • 14050
                                These all look ok to me.
                                What is the voltage to ground of ALL_SYS_PWRGD? Does this pulse?
                                • iMuhtaseb
                                  • Jan 2017
                                  • 122
                                  • Palesine
                                  4.3 million Ohms in resistance
                                  0.460 in diode mode
                                  there's pulse then it drops to 0.0v
