T460s no power
  • mon2
    • Dec 2019
    • 14501
    Remove all power -> meter in resistance mode -> measure the resistance to ground of the L5 inductor. We are only checking if there is a short on this line. Proceed to check each and every inductor using the same process (always without power). If checking resistor or DIODE mode -> never any power to the board.
    Post each measurement and the units of measure which for resistance will be ohms; kohms (thousands of ohms); Mohms (mega-ohms), etc.
    • Kad009
      • Dec 2023
      • 21
      • South Africa
      I'm a bit confused
      on both my multimeters one probe on ground and the other probe one either side of the L5 coil the resistance keeps changing starting at 50 Kohms up to 1.5 Mohms
      • Kad009
        • Dec 2023
        • 21
        • South Africa
        I read that the multimeter applies a very low voltage and then calculates the voltage drop, thus calculating the resistance, which charges the capacitors, therefore varying the resistance. I'm not sure if that is correct. I read that on Reddit. Please correct me if I am wrong
        • mon2
          • Dec 2019
          • 14501
          This is all that matters. You do not have a short on this power rail. Continue to test in the same way, each and every inductor on the board. Checking for a low resistance reading.
          • Kad009
            • Dec 2023
            • 21
            • South Africa
            L32 to ground 19 ohms
            L29 to ground 10 ohms
            L30 to ground 9 ohms
            In diode mode, all the coils beep to ground
            • Kad009
              • Dec 2023
              • 21
              • South Africa
              #26
              I read that cpu coils have very low resistance to ground. Is it that low?
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • WVUfan
                PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
                by WVUfan
                hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
                08-11-2025, 01:12 PM
                by sam_sam_sam
                03-31-2024, 02:12 PM
