T460s no power
  • mon2
    • 14002
    Remove all power -> meter in resistance mode -> measure the resistance to ground of the L5 inductor. We are only checking if there is a short on this line. Proceed to check each and every inductor using the same process (always without power). If checking resistor or DIODE mode -> never any power to the board.
    Post each measurement and the units of measure which for resistance will be ohms; kohms (thousands of ohms); Mohms (mega-ohms), etc.
    • Kad009
      • Dec 2023
      • 21
      • South Africa
      I'm a bit confused
      on both my multimeters one probe on ground and the other probe one either side of the L5 coil the resistance keeps changing starting at 50 Kohms up to 1.5 Mohms
      • Kad009
        • Dec 2023
        • 21
        • South Africa
        I read that the multimeter applies a very low voltage and then calculates the voltage drop, thus calculating the resistance, which charges the capacitors, therefore varying the resistance. I'm not sure if that is correct. I read that on Reddit. Please correct me if I am wrong
        • mon2
          • 14002
          This is all that matters. You do not have a short on this power rail. Continue to test in the same way, each and every inductor on the board. Checking for a low resistance reading.
          • Kad009
            • Dec 2023
            • 21
            • South Africa
            L32 to ground 19 ohms
            L29 to ground 10 ohms
            L30 to ground 9 ohms
            In diode mode, all the coils beep to ground
            • Kad009
              • Dec 2023
              • 21
              • South Africa
              #26
              I read that cpu coils have very low resistance to ground. Is it that low?
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
                03-31-2024, 02:12 PM
              • liquidzorch
                Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                by liquidzorch
                Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                10-18-2024, 05:19 PM
