How to remount this?
  • Almighty1
    • Apr 2014
    • 222
    I was fixing my notebook/laptop computer and the motherboard/mainboard/systemboard standoff which is for securing the bracket that also holds the fan fell off. I would like to know what I can use to re-attach it to the
    mainboard/motherboard/system board. It seems to be some kind of electrical conducting adhesive as it has continuity when I tested the dried out adhesive as it is probably used to ground. Does anyone know where
    I can buy the electrical conducting adhesive online that is strong? Failing that, will first melting solder on the bottom of the standoff first and then position it back on the motherboard/mainboard/systemboard and then
    placing the soldering iron on the top of the standoff cause the solder to melt so it bonds?
    Thank you in advance for your help!
  • Almighty1
    How to remount this standoff ?
    by Almighty1
    I can buy the electrical conducting adhesive online that is strong? Failing that, will first melting solder on the bottom of the standoff first and then position...
    06-18-2024, 05:56 AM
  • Katz993
    iMac Display Replacement Adhesive
    by Katz993
    TL;DR: Looking for as-close-to-genuine as possible iMac Thin Panel (2012-2019) Adhesive.
    Long Rant: I run a tech shop that has a specialty in Macs. We've been doing upgrades and repairs on the thin panel iMacs as long as they've been out, and I've always had the issue of being unable to get something close to the OEM Adhesive for the Display Assembly, i.e. a 'two-part' adhesive, extremely thin but durable and can be cut easily with a thin wheel cutter. My replacement adhesive has always been essentially standard thin adhesive. For a long time, the biggest annoyance with this was having...
    03-15-2022, 10:31 AM
  • caspian
    Touchpad adhesive
    by caspian
    Dear forum members,
    I am replacing the touchpad of Dell Inspiron 5520. I removed the old touchpad. It was glued to the palm rest. Now I should glue the new touchpad by some adhesive to the palmrest. but I do not know what kind of adhesive to use.
    Once I used some wood adhesive. but the touchpad did not work when it was touched. It seems the adhesive blocked the sensing properties of the touchpad. So I removed the wood adhesive.
    By inspecting the smell of the adhesive, I discovered that the adhesive of the old touchpad is not an ordinary adhesive such as super glue, or...
    11-02-2018, 07:26 AM
  • dicky96
    How to desolder power devices on PCB covered with silccone adhesive?
    by dicky96
    Hi guys
    I'm working on some whatspower P222C power supplies. I have short circuits in either or both of the PFC mosfets and/or output transistors. I need to remove at least one heatsink to diagnose this but they are very hard to get to (the device screws) and there is this white sh!t everywhere on the PCB (which is double sided tracks at least)
    Anyone can suggest the best way of working on this sort of thing?
    see pics...
    03-13-2023, 06:22 AM
  • caspian
    The best adhesive on hot heatsinks?
    by caspian
    Dear forum members,
    In laptops, sometimes we need to glue something such as an insulator sheet on CPU heatsink. Or sometimes we need to glue a rubber heatsink on PCH.
    As these heatsinks may reach 50'C to 90'C, it is possible that the adhesive get loose so that the heatsink moves on PCH.
    Silicon thermal paste is loose too. So it is not suitable for gluing heatsink on PCH. and there is no screw to fix the heatsink on PCH.
    what kind of adhesive suites this job that transfers heat properly and does not get loose under 100'C and less?
    thanks
    11-28-2018, 11:35 AM
