HP 850 G6 discharge battery when turn off
  • Inforgalaxie
    • Apr 2023
    • 39
    • Portugal
    I have this computer that when the motherboard is turned off and the battery connected the battery discharges.
    I've already checked the Q60002, Q60003, C6000 mosfes and they're not them. How can we detect where this leak is coming from?
    Link to schematic https://www.badcaps.net/forum/troubl...40-g6?t=108193
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • fauzanmint
    Chromebook can't turn on without a normal battery
    by fauzanmint
    I have several chromebook laptops, the problem is that the battery is damaged. I tried to buy 1 and I tried on all off units can turn on normaally. This means the Chromebook can't turn on without a normal battery.
    is there a way to turn on a chromebook without a battery with bios or hardware modifications?​
    10-12-2024, 02:36 AM
  • huzo
    HP ELITE X2 1013 G3 weird battery issue
    by huzo
    Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
    01-31-2025, 12:09 AM
    EBC-X 8-Channels 18650 Battery Capacity Tester Charge & Discharge 10A Aging Test Modificatio
    This is another battery testing machine that needs to be modified for the cooling fans because these are noisy but not as bad as one of the other battery testing machines that I had modified recently because of it being too noisy
    The battery testing machine is going to get two temperatures controlled cooling fans like one I put in the other battery testing machine I just have to remove the temperature sensor and relocate the temperature sensor to one of the heat sinks and put one on the other heat sink so the fan speed can be controlled by temperature
    https://www.eb...
    05-05-2024, 06:07 PM
  • trepachka
    iPad Air A1475 Boot loops after replacing battery
    by trepachka
    This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
    The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
    I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
    11-08-2024, 03:17 PM
