Alienware M17x R2 no power, no lights, no sound, no boot? Battery not charging either
  • JGAN
    • Aug 2012
    • 28
    Hey guys,
    So I just picked up an Alienware M17x R2 laptop that doesn't work, and I'm trying to get it back up and running again. I believe it has an i5-540m, 4GB DDR3, and some sort of discrete graphics. The problem is quite simply that it doesn't seem to get any sort of power at all, either to or from the battery or from the charger. I have no lights, nothing spinning, blank screen, and no sounds coming whatsoever. Also, I'm only using a single 2GB stick of DDR3 that I'm 99% sure is good for testing, and using the button on the motherboard as the power switch, not the Alienware logo).
    I have tried reseating everything, testing the charger with a multimeter (the charger puts out 19.5+ volts and the blue ring is always on), trying a new charger, with/without a battery, and another motherboard that I was told is good. When I use the other motherboard, I only insert the CPU and a stick of ram, no GPU or anything else. It does the same exact thing, no charging, no lights, no power. Whenever the power and battery is plugged into either of these boards, the Alienware logo does not flash and the battery does not seem to charge too.
    Any ideas? Could a bad CPU cause this? I'm very much completely stumped, especailly after having tried another board. Help!!
    Thanks,
    JGAN
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: Alienware M17x R2 no power, no lights, no sound, no boot? Battery not charging ei
    try removing cpu and ram. then power it up. if no problem with board, laptop will power on but no display. with this you will figure out if processor is bad.
    hope this helps
    • JGAN
      • Aug 2012
      • 28
      Nope, nothing still. What are the chances that both motherboards are dead? Do they need to be grounded with a case when I try them?
      Also, I don't see any charging light on. I tested the pins connecting to the battery, and all the non-ground voltages were in the mV. Can I/Do I have to add resistance somewhere to trick the motherboard into thinking there is a battery?
      • Maj.GHOB
        • Feb 2014
        • 5
        Normally if a laptop is not posting, the first thing to do is remove the battery, hook up the AC adapter, hold the power button for 4 seconds and then power it on and see how it goes.
        If that doesn't work then you take out the RAM sticks and replace them with known good ones and boot it up again. Should that fail then you can start replacing the CPU and the video card daughter board if there is one. If the video card is soldered to the main board then I am afraid you are dead in the water.
        Given the fact that it is an Alienware and they are normally heavily used for gaming, it is most likely the video card that has kicked the bucket.
        • spleenharvester
          • Mar 2010
          • 921
          Are both the chargers you used genuine?
          Remove EVERYTHING except the bare minimum you need to see life - i.e remove wifi card, power switch board, daughterboards etc. Just the board and adapter.
          If it doesn't work then, and both the adapters are genuine, I think you have two faulty boards on your hands. But that seems unlikely to me.
          Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
          • JGAN
            • Aug 2012
            • 28
            I will try this. One charger is genuine, the other is universal.
            Should I still be able to boot without the discrete graphics? The i5 should have integrated graphics IIRC.
            • Maj.GHOB
              • Feb 2014
              • 5
              Ya you can try to remove the video card daughterboard if there is one and see if it will boot up using the integrated intel graphic card.
              • spleenharvester
                • Mar 2010
                • 921
                Someone correct me if I'm wrong but is it possible that the genuine charger has a severed middle wire and the universal adapter doesn't have a middle wire?
                I remember with some HP models the ACDET wire being cut would stop the laptop taking the voltage. But I can't remember the effect it had on Dell-based stuff.
                Also yeah you should be able to boot without discrete graphics. Even if it can't POST without it it should still be able to fire up if there's a short on the daughterboard, at least.
                • JGAN
                  • Aug 2012
                  • 28
                  Well both chargers have a pin in the middle of the barrel. I think it's attached to the outside of the barrel, not 100% sure though.
                  I have tried booting on a second mobo without the discrete graphics, but it is the same problem.
                  • Pascal Komlassan
                    • Jan 2017
                    • 809
                    • TOGO
                    hello please i need the bios of this manchine Alienware M17x R2
                    • wildmermaid
                      • Mar 2018
                      • 6
                      Check the charging port for correct voltage output. Usually a bad charging port leads to laptop not powering on.
                      • Pascal Komlassan
                        • Jan 2017
                        • 809
                        • TOGO
                        Thank you very much. But your bios did not work for my machine. mine is 4096ko it turns on the machine but it does not boot on USB or hard drive
                          • 21679
                          Maybe its your vBios , read this:
                          http://forum.notebookreview.com/thre...17x-r2.646752/
                          • Pascal Komlassan
                            • Jan 2017
                            • 809
                            • TOGO
                            Thanks for all
                            • abajor
                              Alienware Area-51 R2 Boot Loop issue.
                              by abajor
                              I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
                              It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
                              To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
                              Right now I'm trying to dig through the PDF schematics and Board...
                              03-08-2024, 10:08 PM
                              Alienware M17x Gaming Laptop Schematic
                              Alienware M17x Gaming Laptop Schematic...
                              11-01-2024, 04:56 AM
                            • privato89
                              Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                              by privato89
                              I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                              Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                              Let's begin:
                              Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                              03-26-2024, 06:37 AM
                            • joesmoe91
                              Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
                              by joesmoe91
                              My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
                              02-22-2024, 07:38 PM
                            • zwect
                              Dell Alienware 17 R1 / M17X R5 / LA-9331P REV 1.0 - 7 beeps
                              by zwect
                              I have this Alienware 17 laptop with the VAS00 LA-9331P REV 1.0 motherboard that does not turn on anything when power is plugged in and gives the 7 beep sequence, CPU / GPU does not heat up, i tried only with an I5 4200M (the laptop did not come with either the GPU or the CPU, but on the back says that it originally came with the Nvidia 860M and an 4710MQ).
                              While i do not know if there is any CPU blacklisting system on the motherboard, i tried reflashing the BIOS (at UH14) and the EC (at U2) accordingly but no changes either.
                              PCH doesn't seem to be shorted but i haven't done...
                              12-29-2024, 06:57 PM
