HP dk15-1005nc - Bad +3VL rail
  • petr.hlavacu
    • Nov 2020
    • 11
    • CZ
    Hi, i have HP dk15-1005nc (mobo LA-J641P). The battery was accidentally plugged in with the opposite polarity and since then the laptop cannot be switched on. I repaired short in charger circuit, then i discovered bad PU301 (SY8288).
    After the replacement I found that after connecting +3VL to the LDO pin (PJ303 on the board) the LDO switches off immediately. If I leave the contact disconnected, 3.3V for +3VL normally comes from LDO.
    I have tried injecting voltage directly into +3VL with LDO disconnected and the draw is about 0.2A, nothing on the board heats up. The resistance of +3VL is in kOhms - no short.
    Does anyone know where the fault may be?
  • mon2
    • 14791
    In your testing, what is the voltage to ground of ENLDO_3V5V? This is the ENABLE signal used to enable / disable the same +3VL LDO rail.
    • petr.hlavacu
      • Nov 2020
      • 11
      • CZ
      Its around 4,5V.
      • mon2
        • 14791
        This enable is ok to keep this LDO on. When the LDO turns OFF, does this ENABLE signal remain @ ~4v5? (or does it turn off?)
        • petr.hlavacu
          • Nov 2020
          • 11
          • CZ
          Problem solved. The accelerometer (U9) was faulty. I tried again injecting voltage to +3VL, the current went up to 0.3A and at that point it was already visible on the thermo. Interesting that it was not visible in the previous case. After disconnecting it from the board, the laptop works without problems. Thanks for your help anyway.
          • mon2
            • 14791
            Well done! The updates are appreciated.
            • Nagy Daniel
              Lowest possible resistance on laptop motherboard rail - Guide Table request
              by Nagy Daniel
              Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
              I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
              I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
              So, I generated a table with AI so I can...
              03-04-2025, 08:24 AM
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
            • lefetylorant
              Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
              by lefetylorant
              Hello Everyone,
              Long story short, I got this unit for very cheap.
              I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
              I've performed some measurements:
              - 20V rail perfectly...
              09-14-2023, 05:05 AM
            • bimole
              Weird behavior on 3.3V rail of a CORSAIR CX600
              by bimole
              A colleague gave me an apparently ill CORSAIR CX600.
              He told me that he heard a banging noise, and smelt the magic smoke.
              After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
              I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
              It's another story on the 3.3V rail...
              I have some devices to test deeply PSUs (scope, AC source, electronic load)...
              02-13-2025, 04:49 AM
            • mkdj
              Acer TravelMate P214 - N19Q7 main power rail shorted to ground
              by mkdj
              Dear all,
              I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
              I have checked resistance across each of the 4 MOSFETS. I have the following readings:
              Both N-Channel Mosfets: nothing odd
              P-Channel MOSFET number 1:
              source - drain : 117 kOhm
              source - gate: 96 Ohm
              gate - drain: 117 kOhm
              P-Channel MOSFET...
              08-20-2025, 06:08 AM
