Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
This topic has been answered.
  • swerg
    • Jun 2024
    • 6
    Hey everyone,
    I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
    I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
    I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components on this page https://www.mouser.com/c/passive-com...nce=120%20Ohms
    1) Have I identified the blown component correctly?
    2) Which part should I get?
    3) Is a hot air rework station/heat gun and a set of tweezers a good approach for replacing the inductor?
    If I am way off, let me know which direction to go, please.
    Thank you, everyone
    -Swerg
  • Answer selected by swerg at 06-07-2024, 11:24 AM.
    alexfts20
    • Jun 2023
    • 30
    • Kyrgyzstan
    Hello, first, you need to verify that the AC_BAT_SYS_LCD_S net is not shorted and has approximately +19V. You can replace this component with just a soldering iron and some flux. L4502 is a FERRITE BEAD (0603) 120OHM 3A, so here is the link to purchase it: https://eu.mouser.com/c/passive-comp...08%20metric%29
Name:	GX531GX L4502.png
    • alexfts20
      • Jun 2023
      • 30
      • Kyrgyzstan
      • swerg
        • Jun 2024
        • 6
        Thank you, Alex!
        I removed the blown bead and shunted the pads with solder since it appeared to be there for noise reduction only and the screen backlight LEDs work again. I will order the part and do a proper repair.
        Out of curiosity, what software and schematic source do you use? It looks much easier than the PDF schematics I was using.
        Thank you again,
        Swerg
        • alexfts20
          • Jun 2023
          • 30
          • Kyrgyzstan
          swerg You're welcome! Glad to hear you got the screen backlight LEDs working again.
          As for software, I use nextbv.app for viewing boardview and schematic files. The boardview file I found somewhere on Google.
          • silver60618
            Blown Inductor on WD My Passport
            by silver60618
            Hi Guys, my WD My Passport drive powers on, then powers off. Ive taken out the motherboard and identified a blown Inductor. Im trying to recover my data only
            Reading between leads show nothing. If I removed this Inductor, what would be a suitable replacement? am I correct that its a ferrite Inductor is to just filter noise?
            Ive seen people just bridge them, any harm in replacing it with a differnt value Inductor?
            Lastly am I correct in thinking there is no polarity on the smd component?
            Thanks!...
            04-05-2024, 09:54 AM
          • Sus256
            HISENSE 65E7KQ PRO - no boot
            by Sus256
            Hi all!
            HISENSE 65E7KQ PRO
            RSAG7.820.13512 - chassis
            MT9618BAATAB - cpu
            RSAG7.820.12059 - power
            HD650Y3U77 - panel
            KLM8G1GETF - emmc
            The TV does not turn on, the standby indicator is on. All voltages are present.
            Emms is dead. Not readable, not detected.
            Replaced emmc.
            But with another dump there is no launch
            Terminal log
            UART
            AC_ON
            RPMB key is not yet programmed
            HASH1_VERSION=0x00000000 64bit
            E-B
            FDE enabled
            layout pattern onebin by SAR7,0...
            06-01-2025, 02:11 AM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-12-2024, 02:20 PM
          • Jaime Morillo
            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
            by Jaime Morillo
            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
            The TV was stuck on the logo and I couldn't access the update menu.
            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
            The image result was good, but the image is inverted.
            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
            08-18-2025, 11:38 AM
