HP G3 BIOS
  • AdrenalinTL
    • Apr 2024
    • 57
    • test
    HP G3 BIOS
    Hi Peeps.
    Quick question. Might sound silly so bear with me pls.
    After flashing a BIOS with a flashing tool, my laptop went from stone dead, to the fan spinning. However the screen doesnt show POST. Is there anything like pulling out the battery AFTER flashing the BIOS one needs to do or is there another issue I am sitting with now?
  • mon2
    • Dec 2019
    • 14258
    Did the laptop work before the bios was reflashed? If yes, apply the original bios or a known good bios image back onto the bios chip. If you require a known good bios, make that request inside the dedicated bios forum.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Which battery you are talking about-CMOS Cell or backup battery?
      CMOS cell should be always removed before flashing bios.
      Are you sure the new bios is 100% working and me cleaned?
      • AdrenalinTL
        • Apr 2024
        • 57
        • test
        Ah. Did not know bios battery needed to be removed. I am speaking about the CMOS battery.
        Presume the bin file from manufacturers website is ok to flash?
        Flashed that, and orange charge light blinks. No power.
        Flash a BIOS from https://www.badcaps.net/forum/troubl...probook-450-g3 and the fan spins at high rev with nothing on the screen.
        HDMI also shows no pic. external keyboard shows no power.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Use the bios from badcaps for the time being and measure voltages on all the coils.
          Link schematic,if its posted on badcaps forum.
          • Timeeez
            X270 - Bios flashing help
            by Timeeez
            I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
            Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
            11-30-2022, 05:17 PM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
          • Flyview
            Flashing ASUS UX51VZ with correct bios
            by Flyview
            Hi!
            Happy to be part of this forum for my first post!
            Short story:
            I believe my dad's UX51VZ has an incorrect bios (v207) for a UX51VZH flashed onto it. I'm not quite sure what the differences are between UX51VZ, UX51VZA, and UX51VZH. The serial number of this machine is D5N0CY845932229 and comes up as a "UX51VZ-DB103P" when checked on this ASUS website. All of the bioses can be found at this ASUS website.
            1) Do I have the correct bios or should it be the v205 for UX51VZ? Is there something I can check inside the machine to make sure?
            03-31-2024, 11:56 PM
