Dell la-d801p motherboard no power
  • alex26
    • Sep 2012
    • 22
    • ROMANIA
    Hello.
    I need help with a laptop Dell with LA-D801P motherboard.
    The laptop completely died, no power, no leds.
    The voltage of 19V is present at the output of the second mosfet.
    The voltage on Pin 9 and 19 of PU102 is 0V.
    Voltage on
    PU100 :
    pin2 =19v
    pin11 =4.16v
    pin12 =0.18v
    pin17 =0v
    pin19 =0v
    I have 0 ohms on the coils PL100, PL301 and PL700.
    If I remove pjp102 the short remains on the side of +3VALW.
    Then I removed pjp501 and pjp801 but the short did not go to the integrated PU500 and PU800.
    Then I checked UZ3 and here I had a short on pins 6 and 7.
    Here I injected a voltage of 3V and 1A on pins 6 and 7, then I increased the amperage because I couldn't see anything hot under the thermal camera and only at 4-5A did I notice that the processor was heating up. What else could I do and what did I do wrong?
    PU703 I replaced it but it had no effect.
    LINK to schematic https://www.badcaps.net/forum/troubl...74#post1242174
    Any help appreciated, schematic attached.
    Thank you in advance!!!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    PL700 shouldnt be shorted to GND. Are you sure about it?
    However, a dead short to GND on +3VALW coupled with +1.0V rail is almost a sure shot indicator of shorted PCH. So perhaps end of story.
    • alex26
      • Sep 2012
      • 22
      • ROMANIA
      Yes, PL700 and 1.0V is shorted to ground, and thats the end of story. Thanks.
      • Geeker007
        9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
        by Geeker007
        Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
        I am new to electronics repair, so my queries could be naive but I am ready to learn.
        So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
        01-28-2025, 03:31 PM
      • playit
        laptop 19v short circuit dell vostro 1400 motherboard ,need help in repair .
        by playit
        the comon problem they say , the charger will shut off power once plugged to laptop , i dont have battery, its long gone ago , i use it for backup with adapter and vga port to external monitor(yes no screen lcd) in case my desktop needs fix . one thing for sure i could say the clr resistor - r010 beeps ,short at both sides , the checked all the coils , the 3 coils together gives all of them beeps short along with their respective capacitors . i dont have voltage ampere injection dc machine as in videos i have seen they see where its getting hot and they remove the short and replace components...
        02-25-2025, 08:15 AM
      • Julian Bailey
        Dell Latitude 5350 Ultra 7 Motherboard
        by Julian Bailey
        Hi
        I have a Dell Latitude 5350 Ultra 7 Motherboard I am trying to repair that has a blown chip.
        The chip is marked as eHOLH similar to the one I have pictured.
        Any ideas what it does and what the pin outs are as 3 tracks have gone and need to find out what / where they went / did etc.
        Dell PN of the motherboard is 08DCGW.
        Below is the area I am trying to repair:
        Does anyone have a picture of this motherboard in this area they could take and upload?
        Cheers...
        07-03-2025, 11:25 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • gaelican
        Asus ROG ga401IV motherboard - AC Short Protection resistor getting hot
        by gaelican
        I am working on an Asus ROG laptop repair. I was able to find that there is a short on the motherboard, and the 20 volts from the charger only gets to the first mosfet before disappearing.
        When looking around with a thermal camera, I noticed the chip marked "14C" in the picture was getting warm. Nothing else was receiving heat.
        I found a boardview diagram and schematic for a motherboard that looks nearly identical, that has the same component. This appears to be marked as "AC Short Protection" with a value of 13.7KOhms.
        02-21-2025, 01:51 PM
